Other fuel tanks for Savage?
VA
RE: Other fuel tanks for Savage?
buy this:
http://www.neweramodels.com/item.cgi?part_id=1704
there is a link for the side guard as well...
VA
Yeah, a BIG reason.
The beginning of the tank causes the engine to run rich, then it gets VERY lean as it passes the halfway point. If you temp. tune for the bottom of the tank, you spen the first 1/2 so rich that it's just plain weak.
I tried EVERY other mod to help the leaning, this finally worked...
VA
God I don't mean to sound impatient, but I bet a large % of problem/solution posts here and savage-central ARE ALL ABOUT THIS ONE TOPIC...
So to avoid my frustration and the time that it takes to reproduce what has been posted SOOOOO many times, just use SEARCH, hell, here is the link: http://www.rcuniverse.com/forum/search.asp?appid=
hey frost go on tell us all one more time what causes the stock tank to lean ?? LOL is it because the thingy whats it poking jammer is against the big end in the block?? LOL
PA
Well I got a new fuel tank this afternoon, which cracked again an hour later, but this was a small crack and was scealed with CA glue and checked for leaks underwater and it's very air tight.
If I get that other tank that was recommended, will the tank gards I've seen on eBay still fit? And do the ank gards really protect the tank from cracking?
ofna mid tank mod
MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK MID TANK
ORIGINAL: q8
ofna mid tank mod
ofna mid tank mod
hmm, i have never seen that tank before but i am definately gonna buy it because my savage leans out like MAD and the dual tank mod looks annoying and the uniflow mod is just stupid. do you have it done to your savage frost?
