Wheels
IL
Wheels
Does anyone have these? If so, what do you think?
40 Series Commando Bead-Loc 23mm HD Hex Wheel
Monster Truck Enthusiasts beware! There's a new, real bead-loc wheel in town. Introducing the 40 Series Commando Bead-Loc wheel utilizing the 23mm HD Hex system.
The Commando Bead-Loc wheel features a die-cast aluminum bead-loc ring, 18 individual mounting hardware screws per ring for a secure, true fit of your 40 Series tires, a gleaming chrome finish, 23mm HD Hex design for ultra-durability and performance and a chrome center cap to finish the look of the wheel. If that's not enough, the non-gluing, super strong design allows you to interchange your tires with the turn of a 2.0mm allen wrench without having to buy new wheels. This makes your truck totally customizable in a short amount of time.
When you're looking to stylize your monster truck with the latest in wheels designs and technology, then check out Pro-Line's fully licensed Weld Racing 40 Series Commando Bead-Loc wheels featuring 23mm HD Hexes.
CA
RE: Wheels
Great Idea, but I think it's more suited for a shelf queen.
I run the Proline Velocity 6 40 series with Proline Bowties and love them. The chrome finish on the velocity 6's was trashed after two tanks of gas so forget about it lasting on those rims you pictured above.
IL
RE: Wheels
I'm not necessarily concerned about looks but how the tire is mounted to the wheel. Currently I have velocity 6 40 series wheels and dirt hawg tires. Since installing a wasp .28, I need to re-glue the tires after racing and practicing on the track.
RE: Wheels
If you have to re-glue often, chances are that you are not glueing them properly. First, remove all of the chrome where you will be applying glue. Glue the tires where the tire sits on the rim (Not at the bead, but at the innermost part - on both sides of the tire. When that is dry, then glue the bead (i.e. - edge). This makes them rock solid and they will last a very long time!!!
With my first set of tires, I only glued the beads. I reglue them every 2-4 tanks. With my Mambos and Big Joes, I did it the way I described above and have 1.5 Gallons on them without a single re-glue!!!
I run 80% on pavement, so I am brutal on the bead/glueing of a tire...believe me, proper glueing works!!
