Savage SS4.6
Savage SS4.6
I am new to Nitro engines. (I had a Clod Buster back in the day) Anyway, I have broken in the SS4.6 engine, but I am having trouble getting it tuned. Anyone know about how many turns of the high speed needle screw it will take? I have turned it a 1/2 turn so far over tank fills #5 & #6. I notice when the gas tank nears empty the engine leans out and I get a huge boost in power.
Also I think my slipper clutch is too loose. The truck runs fine on pavement, but bogs down in grass. How thight should the nut be that compresses the spring?
Suggestions?
Thanks.
Suggestions?
Thanks.
RE: Savage SS4.6
Took me about 2 -2 1/2 turns leaner on the HSN to start getting decent performance. Also, you will need to lean the LSN some too before you can really get the HSN tuned good, it's just way too rich, but mine only took about 1/4 turn leaner to get half way decent take off. Just take your time and only lean it out no more than about 1/16 to 1/8th turn at a time. And the reason the power jumps like it does near the end is that it leans out quick at the end.
As for the slipper, mine is only about 1/4 turn back from fully tight, any looser and it melts the center.
Also, if your using the stock plastic clutch shoes, it could be those that are slipping, especailly in grass. A good set of aluminum shoes will make a big difference and also saves melting spur gear teeth.
RE: Savage SS4.6
I will continue to tweak the HSN and keep in mind I may need a slight LSN tweak. I will have to look into getting the aluminum clutch shoes too.
Thanks for taking the time to reply.
UT
RE: Savage SS4.6
I'm having the exact same issues. My next purchase was going to be clutch shoes. I can get wheelies on pavement, but it bogs down in sand and deep grass. The K4.6 engines seems a little finicky, but the shoes should help a lot.
RE: Savage SS4.6
If you've got the money, the sliding clutch setups come highly recommended. My lhs guy has a fironi(sp?) one and he's really pleased with it. (Very knowledgeable lhs guy btw) He said after two gallons it's only showing a little wear.
IN
RE: Savage SS4.6
http://www.rcuniverse.com/forum/m_2891045/tm.htm
RE: Savage SS4.6
That problem happens with the ofna tank too. I have the ofna tank and when the tank is on the last few drops the power will become crazy huge right before it completely runs out of gas.
IN
RE: Savage SS4.6
yea.. well all nitro models lean out at the last few drops, but not 1/4 to a 1/2 a tank from empty.. My 4.6 suffers from half tank leaning issue's.. I just installed the ofna tank tonight.. I will see if it solved my problem tomorrow
ON, CANADA
RE: Savage SS4.6
Hey all,
Not sure if this helps at all but according to HPI you are supposed to tune the engine after 1/2 the tank is gone to compensate for the fact that it leans way out the closer to empty you get. Again, not sure if it helps but my buddy tuned his SS this way and there aren't any probs with it at all. I'm gonna tune my engine that way see if it works for me as well.
Cheers
Cheers
RE: Savage SS4.6
ORIGINAL: Crazy Canuck
Hey all,
Cheers
Hey all,
Cheers
"Stop the race, i have to adjust my mixture for my lean half of the tank"
VA
RE: Savage SS4.6
Hey all,
Cheers
Hey all,
Cheers
RE: Savage SS4.6
hey guys
i've melted my 7th spur gear,one on the inner bit couse the sliper clutch was to loose and the others gears are off,what can be the prb? can it be that every time i flip and the angine gets a impact,it moves and eats it,is that a posibility?
i've had the savage now for a bit over a month,ind only had it out properly once,because every time i eat a spur gear. im also strugeling to get my carb set up right,it was running okey but then a mate's mate of mine tamperd with it and it was bugerd,i've cinda got it right again but ran out of spair spur gears befor i could test it properly.
when it runs it goes great but i cant keep the front wheels on the ground it wheelies like crasy!!!
a nother problem is i have jet to find second gear,can you hear it kicking in or how do you know when its set right???
do you get metal spur gears for the savage?
MI
RE: Savage SS4.6
you should be able to tell when it shifts into second. if its not shifting soon enough turn the bottom set screw in the side of the trsns counter clock 1/8 turns.
you wont need metal spurs if you get aluminum clutch shoes.
RE: Savage SS4.6
radio, thats it, but im getting the 3 spd gearbox with mine, and im really thinking about the new venom heat + safe check thingey! it looks amazing. here, http://www.venom-racing.com/ click on the venom smart temp. very very good i be wreckonin, if n e one has one, gimme some feedback looks ace, 2 birds with 1 stone!
RE: Savage SS4.6
ORIGINAL: spareanychange
But I did like it when it was working and it was consistent, just not accurate. Mine measured 15 to 20 degrees hotter than my temp gauge.
