Clutch bell bolt
MO
Clutch bell bolt
Whats the easiest way to get to the clutch bell bolt? I noticed it has backed out a little. I have a stock savage 25. Thanks for any help you could give!
MO
RE: Clutch bell bolt
The bolt that runs through the brass washer and holds on the Clutch bell. I justg read there is supposed to be a 1-2mm gap, and that's what I have....too bad I just took it all apart.
VA
I would think that even a millimeter would be too much. You need to have it tightend just enough to let it spin freely, but not so loose that it moves back and forth. Ya me?
