Troubles removing backplate
Has anyone had any troubles removing the 4 allen screws from the back plate for the engine?
I was thoroughly cleaning my Savage and decided to pull the engine out and seal the carburetor and back plate as suggested in several different forums. I noticed an excessive amount of thread lock that was used during the assembly of the engine. It was caked in and around all the screw heads. After scraping the screw head out with a dental pick I was able to get the allen wrench tightly into the screw head, however, the screws will not budge. It simply bends and twists the allen wrench. After several attempts the screw head stripped. I tried a different screw and it simply broke the allen wrench. I have not successfully loosened any of the four screws.
My concern now is I will never be able to rebuild this engine when the time comes because I cannot remove the stripped screw head.
I believe this issue is a result of the poor assembly of the engine and believe HPI should repair or replace or fix the issue. I emailed them. I'll let you know what comes of it.
Just wondering if anyone else had this problem?
NY
RE: Troubles removing backplate
Get yourself a dremel and thin cut off wheel. Cut a slot into each screw so you can use a flat blade screw driver to loosen. You may want to apply a little heat with a haet gun or torch. Be careful using the torch, don't let it get near the fuel. You only need a small amount of heat and they should break loose.
MN
Heat is the answer. If you can get a dremel blade in there without ruining the back plate I would do that. If this doesnt work I would see what HPI says and pray that they will help you. Those screws are too tiny to use an extractor or ez out. Good luck
This is HPI's response;
I think I'm gonna send it to them to fix only because I believe this justifies a warranty claim. They warranty the engine to be free from defects in workmanship and assembly. It is the excessive amount of thread lock that was used at the manufacture during the assembly that is preventing the loosening of the screws. That is the issue and as a result, one of the screw heads stripped and another screw broke the allen wrench that was provided with my RTR kit.
This should be covered under the warranty.
Hello,
If you like you can send it in and we can try to remove the screw without damaging the engine. Unfortunately we don’t warranty striped screws but we will try to remove them for you. Please feel free to give us a call with any questions you may have at 949 753 1099 ext 505.
Customer support
Customer support
Here is the latest.
We should not have a problem covering that for you under warranty. You are correct in your assumption, if the thread lock was the issue then we will gladly replace the screws and allen wrench. We will also remove it for you.
HPI Support
I only hope they don't damage the engine trying to remove the screws. If they do, at least they are responsible for it.
HPI Support
MN
ORIGINAL: Stablock
Here is the latest.
HPI Support
Here is the latest.
HPI Support
The last thing companies want is bad customer feedback. With the Internet getting more and more popular everyday and new forums popping up all over the place companies would rather bite the bullit on small issue like yours than have 1000 people read about their bad customer service.
It sounds like they are taking the right steps with this one since it was clearly their fault during assembly.
