Hey guys, reciever battery question.
Hey guys, I got my savage 3 days ago and as I was putting in the stock alkaline reciever pack I noticed how small the connectors were. I'm planning to upgrade to a rechargable reciever pack and my charger has Tamiya style plugs. Do I have to buy a new charger or are there some plug adaptors that convert the standard Tamiya plugs to the battery pack style ones?
Thanks. Tom
Thanks. Tom
UT
RE: Hey guys, reciever battery question.
http://www.onlybatterypacks.com/show...temID=10558.17
This is the Battery pack I run, and it runs forever...
GA
I mount mine with two 14" zip ties one from top to bottom and one from left to right, I also dipped mine in plasti-dip for about 3 coats. I runt that same pack but the 2700, I charge it about once a week. Granted I am not running as much because of the cold weather now. But even running my truck everyday I charge it every 3 days.
Yea you should be able to get an adaptor cause my charger came with one, I got an OFNA 1400mah pack and put a charge receptacle on the side of my reciever box, works like a charm, no more opening the box...well not as much anyway.
I had one of these first http://www2.towerhobbies.com/cgi-bin...&I=LXE965&P=ML which worked fine but I decided I would put the charge jack and swith in one with this http://www2.towerhobbies.com/cgi-bin...&I=LXJ778&P=ML this is a lot more work to fit tho.
With both of these mods you will need this (or similar) http://www2.towerhobbies.com/cgi-bin...&I=LX0947&P=ML
To mount a battery to your shock tower just use cable ties.
I'm turning 15 and my dads a contractor
A): I have a problem with finances[:@]
B): I don't think my dad would let me hold a solder gun
