xtm 24.7 engine
CT
xtm 24.7 engine
Has anyone had trouble running there xtm 24.7 in the cold? , keeping the temp up? I seized mine up in 34 degree weather. snapped the rod off the piston. Any pointers on this? I'm guessing the sleeve wasn't properly expanding because of the cold.
RE: xtm 24.7 engine
You must have been revving it before it was warmed up. You can run in cooler temps, but you HAVE to get it up to 230-260 before you start throttling it at all, and it's a good idea to keep the truck in your warm 70 degree house until you pull the starter cord, or at the very least, hit it with a hair dryer for a few minutes before hand. If you leave it in the cold garage, then pull start it and start revving it, it will break.
RE: xtm 24.7 engine
ORIGINAL: jediguru
