savage 25 le trouble..still
got my mt out today to see if i could fix the trouble i mentioned earlier.i noticed that when i accelerate gradually up to full throttle , when it gets to full throttle the servo that does the throttle arm jolts back n forward and the front wheels jolt left n back to the centre
seems like its some dodgy radio interference going on but its been alright till a couple days ago..........
any help appreciated
[:@]need to see this thing runnin smooth again.this thing is sick
RE: savage 25 le trouble..still
hi it sounds like your recever has gone i had the same thing on one of my boats and when i replaced the recever the problem ceased
my trucks only 2weeks old.....do u no why this might have happened.
plus will hpi cover it or if not how much is a new one
Couple things I would check, cheapest to most expensive. If you are still using AA batteries, switch to a hump pack. If you are using AA batteries, use nihm rechargeables and ditch the alkaleins. I use 2500 mah rechargeable Duracell batteries in my radios and they work good. Standard alkalein batteries run down very quickly and will cause problems.
2nd, did you install a failsafe? If so, try removing it and see if your problems go away. I had a similar problem with a Venom Smartemp Failsafe.
3rd, your receiver could be bad. A bad receiver will do that exact thing like zavzilla said. HPI should replace it under warranty. If you call their support, they may have you try a couple things but should replace it for you.
Good luck, post back.
i am using normal aa but have bought some rechargable ones the other day.n i havent put a failsafe on either....probably should though after hearin a couple of nightmare stories.
so u reckon its a faulty reciever n that hpi will replace it for free............i hope so- have to ring um up sometime soon
cheerz for the feedback every1
ORIGINAL: jonmills
i just thought, if it is the reciever, why is it only doin it when i reach full throttle
