HELP!!!savage problem!!
help! the threads on the cover plate behind the engine stripped, so the rotostart backplate vibrates off. so i went to take the cover plate off. there are 4 screws and 3 of them came off successfully but the last one was so tight that i stripped the head of the screw!! how do i get it out!!???!!? HELP!!!!!!!
MN
RE: HELP!!!savage problem!!
Cutting a slot in it with a Dremel and then slightly heating while you try to remove it might be your only option. Those screws are so damn small you cant do much with them. You might have to end up buying a new backplate. Good luck.
MN
ORIGINAL: amitbob21
thanks but how can i get a new backplate if i cant get the old one out?
EDIT: The last resort would be to get a drill that is the same diameter as the head of the screw and drill the head off. After you do that you can pull the back plate off and still have the threads in the block. Then grab really good with a vise grips and heat the area like I said earlier to soften the locktite. Should come out then, but it is a little more work.
