How exactly do you put clutch shoes on?
I have muegen shoes and 1 mm springs that I got for my savvy, but I have to admit I have never put a clutch together. I have a basic idea, but I need a few questions answered. Does the spring end that sticks out go in the groove of the flywheel nut? It seems that it would, but mine doesn't really match up, you would kind of have to bend it in there. Also, what do the washers that came with the set do? I have absolutly no idea where they go, or if you even have to use them at all. Those are the two main questions I have right now, I think I can figure the rest out by myself. Any responses would be much appreciated, I wanna run my truck today .
NY
RE: How exactly do you put clutch shoes on?
The washers go on the flywheel pins, between the pins and the shoes. The keep the shoes from gauling against the flywheel.
Yes, the spring rides in the groove of the pilot nut. If the groove of the pilot nut does not line up with the spring, you may have to bend the spring in a bit. If the groove is WAY OFF, you can shim the pilot nut for a better fit.
ORIGINAL: itspuddingtime00
Easily getting clutch shoes off, and on takes practice. It's a REAL pain. Here is a custom tool I made out of a small screwdriver. I ground a small "V" in the tip to grip the tip of the clutch spring, and get it pushed into the clutchnut groove. I have ripped my fingertips more than once trying to use a regular screwdriver. With aluminum shoes, you need the tiny washers to go on thew flywheel pins first. This creates a gap between the flywheel and the clutch shoe so you don't get any metal to metal rubbing, causing the clutch shoes to bind, and not move freely.
TX
You may want to think about getting a muegen pilot nut. The groove in the muegen is a little bit higher and makes the installation easier.
I ended up bending the springs and it seems fine. I have not run the truck yet so I don't know. I finished building my 4.6 today and have one question. Where does the throttle spring connect to? The carburator arm connector is one side, but where does the other end go? It's not really illustrated well in the exploded view. Also, just out of curiosity, what is the worst that could happen if the springs aren't in the groove of the nut?
Clip one end into the rollbar, and clip the other end around the linkage pivot arm. Much better throttle return precision.
My Feedback: (-1)
I don't see what the big deal is with installing clutch shoes. I do it all the time with a small screwdriver, and have only stabbed myself a few times. It really take practise to be able to get them on and off. I can rebuild a clutch in around 10-20 minutes, including removing and installing engine, and removing and installing clutch bell. I have taken apart my clutch system apart and reassembled enough times to be able to do it efficiently. My recommendation to you would be assemble, and disassemble the clutch system a few times, so that you get the hang of it. Granted tools, custom or not, help, but you really don't need them.
ORIGINAL: mayhem maniac
