HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
2 quick ones
Old 12-29-2005, 07:51 AM
colindecon
colindecon's Avatar
Default 2 quick ones
the savege atv(pictured) is the shocks ok? they are stock but is seems low??
also i wraped my 4.6 for breaking in in freezing conditions? will it work?
ID:	377336   Click image for larger version
Old 12-29-2005, 07:54 AM
podge_87
Default RE: 2 quick ones
mines about the same but i got the orange shocks (not the ATV)
Old 12-29-2005, 07:58 AM
colindecon
colindecon's Avatar
my 4.6 shocks look like this i used 30wt oil
i think my atv is 10wt stock
is that why it higher?
Old 12-29-2005, 09:14 AM
podge_87
because the stock oil is naff in thr RTR, would help a little if u changed to 30 - 35w also the black springs make it ride higher, as the green are softer
Old 12-29-2005, 09:23 AM
colindecon
colindecon's Avatar
green springs are the color of the atv i dont like to change that.
but i will change to 30wt silicon, thanks.
Old 12-29-2005, 09:27 AM
podge_87
try adding more spacers to the top of the shocks that will also help to increase ride height, keepin the truck lower also has advantages tho, ie turnin better
Old 12-29-2005, 09:31 AM
colindecon
colindecon's Avatar
oh i see cool:P
what about my 4.6 head wraping freezing breakin??
Old 12-29-2005, 10:10 AM
savageman90
My Feedback: (12)
yah that should work... i see you used tin foil and a sock
Old 12-29-2005, 10:47 AM
colindecon
colindecon's Avatar
cool thanks.
heat cycle here i come.
i will tune my atv today i heat cycle it at the weekend (hope i did it right first time) fingers crossed
Old 12-29-2005, 12:41 PM
bagged97
You might see if the shocks need a little more oil. If they're not full, they'll sag like that. However you don't want them so full that the shock can't compress. Fill them to the point that the oil makes about a .5mm to 1mm bump, then cap em off. If it is sagging cause of low oil, cramming spacers in there will keep the shock from acting like a shock and the ride will be very bouncy.
Old 12-29-2005, 01:32 PM
sledmanass
sledmanass's Avatar
i suggest putting the black springs on your atv, and then just paint them green, and no one will ever know.
Old 12-29-2005, 04:18 PM
azzman
azzman's Avatar
Oil wont effect ride height. Oil provides damping for the shock only. your truck should "sag" a bit from the weight of the truck for maximum efficiency.
Colindecon, when you lift the truck up how much do the wheels drop?
Old 12-29-2005, 05:07 PM
bagged97
It shouldn't sag as much as his pics show. If there is any air in the shock the truck will sag. Making sure the shocks are full of oil will prevent it from sitting so low.
Old 12-29-2005, 06:01 PM
colindecon
colindecon's Avatar
the wheels drop lots i think i will top them up and see what happens
Old 12-30-2005, 05:25 AM
podge_87
ORIGINAL: azzman
My Bad, Sorry
Old 12-30-2005, 05:53 PM
colindecon
colindecon's Avatar
i topped up the shock oil now it looks better
Old 12-30-2005, 05:59 PM
bagged97
Cool. Aren't quick fix's the best?
Old 12-30-2005, 06:01 PM
azzman
azzman's Avatar
ORIGINAL: podge_87
ORIGINAL: azzman
My Bad, Sorry
No, MY bad...sorry
