happy new year....not for me
urgent help is needed. first of all im new to rc but have been the proud owner of a savage 25le for the past 2 or 3 weeks. breakin seemed to go alright n got better from then on up untill abit before xmas. i noticed that when i accelerated upto full throttle the throttle servo arm jolted back n forth between full and 3/4 throttle, aswell as the front wheels twitching to the left n back.
i posted before n had a few responses giving me numerous things to check.somebody said about metal t metal contact and after this i noticed the brake linkage was touching the roll bar when at max throttle....so i took it off to check for improvements n it seemed to be working....
anyway....took it out today n abit after getting it warmed up the same thing happened.
can any1 offer some advice.... or.... if uv had a similar thing happen to ya... some feedback wouldnt go amiss
cheerz once again n
happy new year
cheerz once again n
happy new year
OH
RE: happy new year....not for me
If you've tried new batteries, no metel to metal contact, and the reciever and antenna are OK, I'd check with HPI, or the LHS (if you bought from there). It may be something you cant fix. I was at the LHS one time and a guy brought his truck in and the controller actually started smoking! (I didn't see it, just took their word for it).
Someone my chime in here who has had the same problem, and give you better info...
i did snap the antenna the other day but checked the wire n all looked good. just had another look though and noticed when i lift the back end, when the shock springs r at full extension the spring slightly touches the exhaust header (i think thats what its called).
could this b doin it
cheerz 4 replying
cheerz 4 replying
AK
mine did that in 3 diferent locations. all were within 2 miles of an airport. i would fire up and the throttle
would open up and the steering would go crazy. my radio acted like it wasnt even there. one time it took off at about full throttle and hit a car. no damage of either thankfully. so my rule of thumb is i play no where near a airport. problem is we have them radar things all over the place.
its never done it again since i stay away from airports. its worth a shot moving to a new location before you buy new gear.
also the funny thing was it wouldnt act weird till it was running. i could turn on truck and radio and nothing would happen, then fire up truck and it would go berzerk.
