k4.6 vs. picco .28
ORIGINAL: 46u
Should be a drop in other then what you are going to use to start it. I say pull starter as most know it is all I will use.
ORIGINAL: neko878
On a stock X can you just put the Picco .28 straight in? Or do you have to upgrade any gears?
Also you should use atleast 18/49 gearing with this engine.
