View Poll Results: A poll
Voters: 22. You may not vote on this poll
lrp .28 spec 3 vs. axial .32 spec 1
WI
RE: lrp .28 spec 3 vs. axial .32 spec 1
The LRP .28 spec 3 is an 8 port built more for speed then torque. I dont know about the axial. Im sure both could pull the wheels up no problem with the right gearing though.
I know what the axial .28 port configuration looks like; it's virtualy identical to that of a Nitrostar (HPI) K4.6. I actually toyed with the idea of buying the axial sleeve and piston and ruibuilding one of my K4.6s with it; but I didnt want to drop $100 for the rebuild when I could get the k4.6 rebuild at $50.
Can you post pics of the lrp sleeve? It would be a little easier (but not accurate) to guestimate what the LRP sleeve is menat for (low RPM, more torque or high RPM and high HP).
NY
http://www2.towerhobbies.com/cgi-bin...&I=LXKYU8&P=ML it says it is 6+1
the axial is 8 port
the axial is 8 port
i voted axial .32 tons of torque. i had it in my mad force but it was way to much, so i got the .28 and its still to much!
You can get the axial .32 at tower
http://www2.towerhobbies.com/cgi-bin...?&I=LXPEB7&P=7
Gray
http://www2.towerhobbies.com/cgi-bin...?&I=LXPEB9&P=7
Gray
NY
how much more power does the axial .32 have compared to the .28?
mine can wheelie when it geared way up,
whats a good pipe for the .32? is the ofna jp-3 a good one?
ORIGINAL: zach brenner
why the jp-2 not the jp-3?
NY
o.k I get the jp-2-if my neighbor start getting pissed i'll swich to the jp-3.
so is the lrp .28 really better than the axial .32 even if the axial is a lot bigger?
I the lrp .28 hard to tune?
I heard it has high compresion so it needs a long break in, is that true. ?
My lrp is a dream to tune it is very dossal but yes with high compresion it was harder to start for break-in but after that it starts up super fast even in cold weather, the pull start on mine was junk it lasted break-in so after that I went to a tiger drive #S-704. The pic and description on tower hobbies is wrong (but I believe thay ship the right engine) the spec 3 is 8+1 port here's a link
http://www.modelsport.co.uk/?CallFun...n&ItemID=24999
By the way my spec 2 is very powerfull it will lift the front wheels up in the air very easly with 16/49 and 7'' tires and with 14/52 it will do full back flips but I try not to because it's hard on the diffs.
