HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
break in woes!!!!!
Old 03-24-2007, 06:19 PM
SioXiE
Default RE: break in woes!!!!!
Thanks Guys all your advice, for taking out my engine, all i did was remove the 4 rear end screws in my right tvps and unhook my pipe and fuel tank then remove the 4 allens screw at the base of the engine mount not at the bottom and voila!!!! never thought that taking out my engine was that simple. i dont even have to adjust my gear mesh!!! bcoz my engine mount stays exaclty the same spot. wish i have pics to show you.... just like Benzzyo5 said.
Old 03-24-2007, 06:48 PM
SioXiE
Guys i just replaced the one way bearing (im suspecting the old one is ok) with a new one to be sure and then reassembled the engine and tried to finish my break in but i still got the same problem!!!! so i took the engine apart again all the way and remove the entire back plate --- the result is a broken backpressure spring as what my LHS calls it (wish i have pics) part 11143 i gues with a pin on it that connect from the crankshaft no wonder its not turning with the one way bearing. My LHS calls it a rare occurence especially that my engine is stil new, must have been a defected part. im gonna call HPI for a replacement and hopefully they respond soon.
Old 03-24-2007, 06:58 PM
SioXiE
As for the fuel, definitely will go with Byrons from now on , i think its a cleaner and better fuel lyk u guys said it. Like most NEWBIES theres always a first time for everything it just that we have to learn from our mistakes (and the HPI/factory mistakes!!!!!) and avoid doing it again!!! Thanks guys for all yor help i learned a lot!!!!
Old 03-24-2007, 07:01 PM
SioXiE
definitely no sharing of fuel this time... LOL
Old 03-24-2007, 09:16 PM
Vigilante212
Vigilante212's Avatar
Always double check your mesh when removing the engine just to make sure its good still. Just hold one gear and wiggle the other if it has a little play its good.
