Axial 28 Question
PA
Axial 28 Question
Hey, Im about to purchase an Axial 28 for my bb tmaxx. Since you guys run them in your savages, could someone please tell me the best glow plugs to run in the axial? Im going to buy the engine off towerhobbies so a link from there would help a lot. (The motor is $119 plus tower has a $25 off an order off $125+, good deal!!) Thanks in advance.
NY
RE: Axial 28 Question
http://www2.towerhobbies.com/cgi-bin...&I=LXPDU9&P=ML
and i use this glow plug with 20% nitro http://www2.towerhobbies.com/cgi-bin...?&I=LXFRE9&P=7
PA
Thanks for the link. Is there a plug a little less pricey that will do the trick? I dont really want to spend over $6 a plug. If theres a cheaper one that works well with the axial can someone show me, or is the hpi one the best choice?
GA
http://www2.towerhobbies.com/cgi-bin...&I=LXRA06&P=SM
I used that one for Break-in, gets the motor hotter faster, I did heat cycle.
http://www2.towerhobbies.com/cgi-bin...&I=LXRA02&P=SM
I run that one with 20% O'Donnels race blend. I rarely see temps over 240* without a body, and never over 260* with the body. I like the med to cold of the MC-8 because it is rather warm here. In the summer I will probably run a cold plug.
