Will a little bit or extra fuel line stop the lean bog?
Hi as you probably read my other thread i recieved my savage x ss today,and the fuel line is loose making a semi circle shape.Will this help me not getting the half tank lean bog.And does all savages have the half tank lean problem, or is it a chance of luck if you get it or not? Thanks.
RE: Will a little bit or extra fuel line stop the lean bog?
ORIGINAL: naynay12
And no not every Savage has half tank lean, but it can be tuned out to some extent anyway.
how can you yune it to get the lean bog out of it??Do you lean it or richen it?
ORIGINAL: naynay12
SK, CANADA
man i didnt realize i had another lhs in town so i was using crap fuel for a while
just put some trinity monster fuel on hold so im gonna be happy
ORIGINAL: lpa12threh
Ok,Anyone have heard of Hot Stuff and know if its a good brand of fuel(20%) and that i will or will not get the half tank lean bog?
The half tank leanout is result of the HPI fuel tank design. Extra fuel tubing *might* help a little, but by no means will it cure it. I compensate for it by running a tad bit richer on a full tank, so when it hits half a tank the leanout isn't as drastic. I'm surprised HPI hasn't redesigned the tank after all these years of us complaining about this.
hummmm.... never heard of hot stuff... i run byron, love it.. alot of oil.. 11% content and they say anything over *% is waisted and makes you you your engine leaner due to the false visual effects of the truck,
the only other fuel than byron i would suggest is blue thunder or tornado, i dont no the oil content but check them out... fuel is important to the life and performance of your mill, re run your truck in with the fuel, back to base settings and re-tune, maybe even change the plug and start a fesh!!...
I think Blue Thunder is a very high oil content fuel, in the high teens pusing 20% if not more than 20%. O'Donnels and Byrons are good brands with 12% oil or less. Another brand I reverted back to useing is Rocket Science. I hear that fuel is popular only in the south so you might have to ask your local RC store to order it.
As for the half tank lean, I did an explanation on it in which I went into some of the physics involved as far as presures are concerned and how a significant pressure drop would cause the half-tank lean. I'm going to search for it and if I can find that post, I will link it here or bump that thread up.
NY
i use 20% byrons race blend works great not everly messy with oil just right and clean sounding, it has 12% oil
also i would just get the new era tank
