aa batteries
BC, CANADA
RE: aa batteries
They sure dont last long in the reciever, I had to get a re-chargeable hump pack and its awesome! Before I had to put in a new set of batteries every time I went out. The 6 volt hump also gives more power to my servos.
GA
RE: aa batteries
Yep hump pack is the way to go for the RX and I use 15 minute rechargeable AA in my TX and they last a long time. But I recharge them before each race day to be on the safe side.
RE: aa batteries
whats rx and tx .... i was thinking of using the energizer recharchable ones .... so whats a goog hump pack to use with the savage
RE: aa batteries
I do the same as 46u
any brand of hump pack will do, just get a 6 Volt with atleast 1400mah
http://www2.towerhobbies.com/cgi-bin...&I=LXNMD7&P=ML
My Feedback: (7)
KY
RE: aa batteries
Don't use rechargable AA batteries in your receiver. By doing this you will drop the amount of power to you electronics. A regular alkaline AA is 1.5volts and a NiMH/NiCad AA is only 1.2volts. Thus taking you down from 6volts of power to 4.8volts. Buy a hump pack, you won't regret it.
RE: aa batteries
ok ill get that as well and for the control regular batteries will do right???? also how am i supposed to charge the batterie lol sorry im new to this i wanna make sure i have everything i need for when i get my new savage
RE: aa batteries
rx is the receiver
tx is the transmitter.
Go with a receiver 6 volt "hump pack" in the truck, you can get a charger cheap enough on ebay.
Alkaline AA batt's in the rx give more volts than rechargeable's, 12 volts compared to 10.4.
RE: aa batteries
I get about 1.5-2.5 hours continual use out of a 1400mah rx pack. Is the 3000mah pack from the Baja? If so it will not fit in the Sav. There are batt's for sale on ebay with high capacity however they take up the space of the reverse servo as well.
RE: aa batteries
will this one fit http://www.hobbypeople.net/gallery/358429.asp also is any glow initor good or it has to be a specific one?
RE: aa batteries
The 3000mah is for the Baja, wont fit, the orion pack also wont fit in the radio box. Sorry
Unless you have another charger this set would do you well. You would get many hours use out of the battery, then charge it. It would take 26 hours to fully charge from empty though.
I use a Swallow charger for all my batt's, from Li-Po to Ni-Mh. Does them all. Not the cheapest but very good.
http://cgi.ebay.com.au/6V-2600mah-Rx...QQcmdZViewItem
RE: aa batteries
ok so i get over a gallon of run time wic hi dont know how much time it is lol and if i use regular alkaline batterries how long do they last??? you guys are really helpfull thank you i apreciate it
RE: aa batteries
ORIGINAL: amec
rx is the receiver
rx is the receiver
i think he meant to say tx
about the glow ignitor, anyone is good
also helps if you get the one that has the battery level thing on it so you can tell when to charge it
RE: aa batteries
why is this one http://onlybatterypacks.com/showitem...temID=10165.17 cheaper then this one http://onlybatterypacks.com/showitem...temID=10983.17 if the first one is 2700mah???
RE: aa batteries
http://cgi.ebay.com.au/1400mah-Savag...QQcmdZViewItem
This type fits and the reverse servo is fine as well.
This charger will work as well.
http://cgi.ebay.com.au/REVO-Power-Ch...QQcmdZViewItem
