diff problems
if tighten the diff hub down it is notchy and locks up if i loosen it up it works great but it will leak. do they make any shims for this if so where can i get them. any other suggestions would be great. thanks
I found that issue when trying to shim it. Without the shim, I was fine. Shims will only make it tighter. Are you using an aluminum diff cup? Which one?
