Cant get my Carb off?????
BC, CANADA
hey guys i cant seam to get my carb off my F4.1 i have removed the pintch screw but it wont move at all[:@][:@]
any quick help would be much awsome thanxs guys
Cory
Cory
My Feedback: (10)
CT
RE: Cant get my Carb off?????
I had that problem the other day when i had to turn the carb around on my Axial .28RR i just tapped it firmly with the back end of a screw driver first tap it and get it to turn then tap the carb out, it worked for me
BC, CANADA
i dunno I have pulled soo dam hard on that thing and nuthin it wont even spin[:@][:@]i know theres a air leak there too i wanna seal up [:@][:@] soo is there nuthin i can do??
BC, CANADA
I was tryin that but i didnt want to come maybe ill get rough with it meh i put it back together and its running pretty nice soo ill leave it till i take my block out again
My Feedback: (10)
CT
dont take the big screwdriver to it it does work trust me just hit it really hard with the back end of a screwdriver it gets it off without damage
If you can't take it off just clean the out side of your engine/carbie, then seal. It may not lok good but at leat you sealed it, just a thought
Or, you could try heating it up a little bit. That might make it expand enough to come off. You could just take it and put it in the oven for about 10 mins or so at abotu 300°F after you've taken all the rest of the engine apart so that it's just the carb and engine case.
