Braking Kills Engine
Hi I Have A Savage X and whenever i hold the brake it kills the engine i dont realy know what to do so if anyone could help that would be great thanks
RE: Braking Kills Engine
check your idle screw it's probebly screwd out to much so when you brake you bush the throttle back to much.. not letting any air into the engine
NY
if its running perfectly then u could check out ur clutch assembly.....there might be something keeping the clutch engaged..like not haveing the correct shim
welll i think theres a combination of probs cause i did what Heatfire said and it worked perfect for a while then was doing the sam old thing.also since i dont have a matching spur gear and clutchbell could that do anything(besides eat away my spur and clutchbell)
WI
With the engine off turn the reiceiver on and check the linkages. apply the brakes and check to see if this forces the carb arm closed with the airfilter off. You need 1-2mm gap for idle.
well i did everything u guys said and it works way better than it did but now i have anotehr prob i snaped one of my 9x123mm dogbones
WI
lol but the non HD ones if you have silver ones they are HD if they are black they are non HD. The heavy duty ones snap alot I went through 4 in 6 months.
well i was realy surprised when this one did i mean it was a clean snap and i wasnt more than 4ft in the air although my truck landed on the front right and right back tires only so wich ones should i get i dont realy bash it hard but i will be soon heres a vid i upped its what i normaly do http://rcuvideos.com/item/T9HMXGT81GGC88TT
