"Leading" Clutch Shoes Direction
Good Day
I just tried to ran the savage with the clutch shoes installed the opposite direction and I'm starting to appreciate it. Even if I'm using a 1.1mm clutch springs,the shoes really engages aggressively even if you blip the trigger! It also wheelies the same as the stock direction.
Can someone tell me the pros and cons of this kind set-up? I usally bash on paved surface/grass and occasionally race in our local off-road track. Will this have an ill-effect on my clutch shoes and engine?
Thanks!
Carl
Thanks!
Carl
RE: "Leading" Clutch Shoes Direction
No, no ill effects should occur. Just run them normally and you will not have any problems, bashing or racing. Let me check the positioning of your shoes though.
Edit: Never mind, your shoes are positioned correctly. [8D]
ORIGINAL: carldav
Good Day
Thanks!
Carl
Good Day
Thanks!
Carl
And this is what I don't like about aluminum clutch shoes and 1.0mm springs. It engages too harshly for me...and all it does is want to flip over backwards. I'd prefer a stock setup honestly for that reason alone.
Having the shoes backwards won't have any ill effects as SavageJim said.
CA
Except that you might see lower clutch bell temps because of less slipping. I run my shoes backwards on the savage all the time and have always had good results.
Its a matter of physics and geometry. By pitting in the shoes backwards, due to the location of the center of mass of the shoe being cnanged in relation to the hinge pin of the flywheel, this will cause the shoes to open sooner.
ORIGINAL: SAVAGEJIM
Its a matter of physics and geometry. By pitting in the shoes backwards, due to the location of the center of mass of the shoe being changed in relation to the hinge pin of the flywheel, this will cause the shoes to open sooner.
He said from a pure Physics standpoint, the mass of the clutch shoes doesn't change nor does the pivot point so center of mass and such will also not change (the shoes don't know the direction has changed). Also the surface area of the shoe contacting the bell is also the same. Now my only thought is something along the lines of aerodynamics of the shoe, but there's no way for me to find out. Well I *could* but that would mean bringing my truck to work and building a rig to measure it all. That ain't gonna happen!
All that aside...you guys actually notice that the shoes engage sooner when oriented backwards? That'd be interesting to know for sure.
I'm definately going to add the set screws to my aluminum clutch shoes to lower the engagement RPM. As it is now they come on way too high and hard. With an Axial .28 it just makes for a hard to drive truck that only wants to wheelie and flip over.
ORIGINAL: SAVAGEJIM
Thanks Savagejim I love running the Savage with this kind of set-up.
CA
It is a matter of friction and leverage. As the clutch shoes start to engage the clutch bell, friction forces them back and the leverage helps push them into the bell. Motorcycle brakes used to be of the drum and shoe type. Normally they would have l large shoe in leading edge position to do most of the stoppilng going forward and a smaller trailing edge shoe to do most of the stopping when rolling backward. High performance motorcycles of the time would have two leading edge shoes in one brake drum for better stopping power when going forward. Staying stopped on a hill required more brake pressure to keep it from rolling backward because both brakes were leading edge.
Anyway, you get a more agressive engagment with leading edge clutch shoes and a little softer engagment with them in normally. With the Big Block high torque engines of the 28's and 30's, a more agressive engagment results in less slipping time and less heat.
Dennis
Dennis
