HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Reverse Modules?
Old 10-18-2007 | 12:30 AM
Default Reverse Modules?
ok, stupid question probably.....
what's the difference between the reverse module (HPI 87032) and the reverse module with mixer (HPI 87039)?
which one works in the savage 25 3-speed transmission? (HPI 87220)
if both, is there REALLY any reason to go for the one with mixer when it appears that it's going to be about twice the price?
Old 10-18-2007 | 01:02 AM
pythonfan's Avatar
Default RE: Reverse Modules?
ok the hpi reverse, and reverse with mixer, there is a big to slight diff.
the plain reverse one u need to have a 3ch radio.
the one with mixer allows you to use a 2ch radio, you do need an extra standard servo for both but that's the real diff in them.
here are the pro and cons of both:
HPI 87032:
Pro's:
cheaper
allows u to decided when u shift
cons:
requires a 3ch radio
standard servo
HPI 87039:
Pro's
use a 2ch radio
con's
price
standard servo
shifts after a delay period, if not set up right can cause damage.
that's really it. cause the price of the reverse and mixer is about the price you will be spending on a 3ch radio plus the standard cost of the 2ch. so a standard 2ch is 50 expect at least 75-120 for 3ch.
Old 10-18-2007 | 01:20 AM
ok, so seeing as I've got the DX 3.0 I could quite safely go with the regular one then, right?
Old 10-18-2007 | 01:25 AM
MiamizFinest's Avatar
Yes
Old 10-18-2007 | 01:33 AM
thankee much....didn't want to pull a stupid and buy the wrong thing
Old 10-18-2007 | 02:16 AM
pythonfan's Avatar
its ok thats what were here for.
Old 10-28-2007 | 01:01 PM
i thought the stock hpi transmitter was 3 channel? my mistake if it isn't[]
Old 10-28-2007 | 01:41 PM
mazdab2600's Avatar
i just put reverse in my lrp savy.
just testing it to see how well it works.
using the hitec aggressor srx 3 channel.
works great with a 3 channel radio.
stop shift reverse stop shift forward.
not sure about the mixer's for a 2 channel.
are any of you guy using them(mixers) and haveing troubles?
Old 10-28-2007 | 01:42 PM
Banned
mixers are a drag dont buy them , plz for the luv of god!!![&o]
Old 10-28-2007 | 01:47 PM
mazdab2600's Avatar
ORIGINAL: cleek
i'm not. just want to see what everyone thinks of the mixer.
i'll stick with the 3 channel radio's for reverse.
its a more solid shift compared to the mixer's.brake 3sec's shift(maybe)grind gears etc.
i think.
