Clutch shoes
MT
Clutch shoes
After bashing today I think I need new clutch shoes. How can you tell when they have went bad. I will be tearing apart and looking but was wondering should you be able to tell when running? I was running great the first tank but then on the second it would cut out. It would start right back but the run and cut out. Like every time I let off the gas it would just die or start to putter... I cant seem to find an air leak and my tune seems to have plunty of smoke. Actually I think it may be on the lean side.
Also need help on clutch shoes. I looked on ebay and there is a ton. What do I need and want to get. Thanks guys for any info and if you have a link that would really help..
MT
RE: Clutch shoes
After taking a look at my truck I noticed that the little think that the throttle and brake connect to was loose... The screw is backing out on me and I cant seem to get it to stay put. Anyone know what it is called and where to find a new one.. I would like to upgrade this so it would be nice if you had a link..
MT
RE: Clutch shoes
Thanks for the link.. I would like to find all the stuff I need to do that mod on tower if you know what I will need. But what is backing out on me is the throttle mix arm screw..
Has anyone used this one?
http://www3.towerhobbies.com/cgi-bin...?&I=LXTTH1&P=7
