Lsn tuning
Lsn tuning
Just want to know with the lsn when tuning,you can pinch the fuel line and it should cut off in about 3 seconds.Wjere do i pinch the line sunce some poeople say near the nipple and some say 1 inch from the nipple?
RE: Lsn tuning
Ok,so where ever i pinch the fue line the engine will shuit off at the same amount of time?How does that work(i though the ffurther away from the carb nipple the lonbger it takes for the engine to shut down...
RE: Lsn tuning
Just go somewhere between 1 inch and the nipple and do it in the same place every time. Its not the time it takes to shut off its the sound it makes.
If the low speed needle is set correctly, the engine should increase rpm only slightly and then die.
If the engine increases several hundred rpm before dying, then the low speed needle is too rich and needs to be turned in.
If the rpm doesn't increase at all and the engine simply dies, the low speed needle is set too lean and should be richened or turned out.
