Visiting shocks again...
KS
I took the Truckzilla out today and was trying to climb a large pile of wood chips. It kept burying itself into the chips, so I kept adding a little more speed. At any rate, some time in the abuse I managed to bend two more aluminum shocks. These are the Hot Bodies shocks with the threaded body. I like the way they look, adjust and handle on the smooth, but they really seem to bend easily.
I know Integy reservoirs are junk, they were on this chassis when I bought it.
I am curious how the guys that bought the Hpi Big Bores are getting along with them, now that they have been running them for a while. I am looking for a review, before I blow more shock money. Maybe a set of stockers is what I should pursue....
It may be time to think about buying some towers and different brand shocks....
Another set of XL plates arrived yesterday, so this may be the last run for the old Truckzilla plates. Just think, a few months ago that was my favorite chassis.... Thanks .... Bud
KS
RE: Visiting shocks again...
I guess I only ruined one, the left front. At any rate, the shaft is quite a bit heavier than the stock Savage shock, but apparently not as tough.
ORIGINAL: BudBud
KS
I do have a set of LST shocks on an EK4, I guess I could just buy mounts and/or towers and steal them off of the other truck.
The Hb shafts are longer and larger in diameter than the Hpi shafts, the shock is a completely different design internally. I really wish somebody with bog bore experience would chime in.
anybody...
anybody...
You are running very flexible nylon suspension arms and rigid aluminum shock bodies... Guess what is going to happen when the wheels are subjected to an impact that causes the suspension arms to elastically deform? Yep, the shafts will bend. I only run stock plastic shock bodies, because they elastically deform in a similar manner to the arms when force is applied to the shafts, which substantially reduces the reaction forces exerted on the center of the shafts by the bodies. I still bend shafts occasionally on very high jumps, but I really doubt there is an R/C shock in existence that can withstand repeated drops onto one wheel from 15+ feet.
KS
ORIGINAL: HPI_Savage_RC
OH
BB, I think you need vigilante's low-profile shock towers, some Jammin X2CRT rear shocks (x4), and then you can do the lowrider body.
Seriously, though...HPI_Savage_RC explained what I could never put into words...which I think is part of the reason I've had so much trouble with shocks since I decided to ditch the stockers.
Perhaps I should go aluminum lower arms (UGH I hate even THINKING that...)
I seriously doubt, unless it's just a straight-up CRAP choice in materials, that your shock shafts would've bent under compression before the jump with 20 wt oil.
KS
ORIGINAL: ThunderbirdJunkie
