This thing is starting to annoy me...
My Feedback: (10)
IL
Every single time that I try running this damn thing, it either takes forever to start, or it DOESN'T start at all! [:@]
I use a cordless drill with the shaft that came with the roto-start. Battery on the drill is full and the tq is set to low.
Today I primed it, tried turning it over and then primed it some more. After I primed it some more and tried starting it, it sounded like it was about to start for a few seconds and then it just went back to its normal dead popping sound. Glow plug is good, glow igniter is good...so ***?
I just wiped off the carburetor and after doing all of this, the bottom of my filter hose thing is slightly wet from fuel. Could the carb be acting as exhaust?
Please help because I don't want to drive to my LHS every time this thing is a PITA.
thank you and excuse my anger
dan
dan
ME
RE: This thing is starting to annoy me...
you could be flooding it each time you try to run it. try this take the hose going to the tank to the muffler .pull it off the muffler and put it in your mouth and slowly blow while watching the fuel line going to the motor you will see the fuel slowly going through the line and stop blowing when it just hits the carb [ no air bubbles ] don't blow the fuel in the carb . and make sure your glow starter is fully charged and make sure your plug is in good shape also make sure the tank cap has a good tight seal and open the carb a little bit with the knob on the controller. work for me everytime
WI
just sounds like a bad tune to me? try setting it back to factory and go from there or have an expert tune it for ya
My Feedback: (10)
IL
I figured that my cordless drill method would have its disadvantages
When I went to prime it with my finger blocking the exhaust, it wouldn't prime it enough. Guy at LHS plugged the carburetor, primed it and it fired right up. [sm=red_smile.gif]
ORIGINAL: fasterrcs
PA
i do the same thing fasterrc's does. the other way takes to long and wears at your OWB.... are you giving it enought throttle when trying to start it?
Pull the pressure line off the pipe, blow into it until fuel hits the carb inlet nipple, put the line back on the pipe, slide your roto shaft into the hole, hit the drill and it should fire up instantaneously if you did it right. If not, you didn't prime it right or your drill isn't spinning fast enough to get it fired up.[8D]
You are only going to be able to control it if you stay with the stock tank. That's the main reason it happens-the stepped tank. Some guys shorten the fuel line, some run the carb a bit richer and some just refuel when the tank gets half empty. All methods will work to a degree to lessen the impact, but it never really goes away per se until you put a non-stepped tank on it.[sm=spinnyeyes.gif]
My Feedback: (10)
IL
So I have the shortened line that goes from the tank around the engine and to the carb.
I've just been reading up on it and quite a few people say that they LENGTHENED the line to make the half tank lean go away...so which way is it?
I can only control it with the stock tank, but it goes away with a non-stepped tank? Doesn't that cancel itself out? lol
Yeah, changing the tank gets rid of it. The way I get around it is to fill up between half a tank and a quarter tank. Easy enough to do.[sm=shades_smile.gif]
Yeah shorter tube. I cut about 3" off of my line and let the tank go just about empty and the truck didn't seem to exhibit any noticeable leanout symptoms. Maybe there is something to running a shorter fuel line?[sm=idea.gif] This is perfect because my 5.9 empties a tank pretty fast...........and refilling every couple of minutes when it hit half a tank was a pain in the arse.
