Stripped 3 servo horns
IL
Hey guys new here mostly fly Heli's but I bought my wife a Savage 4.6 and put a Hitec HS 645 servo on the steering and have stripped 3 servo horns. What do you guys suggest for a good servo horn that will hold.
IL
RE: Stripped 3 servo horns
Sorry guy but I don't understand "Ofna makes a great servo arm #10731" I have never had one of these trucks so I have know idea where to get parts except my LHS.
BC, CANADA
VT
ORIGINAL: saxy174
sorry, here is a link from tower hobbies...
http://www3.towerhobbies.com/cgi-bin...0731&search=Go
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFVK9 you'll need to drill out a hole and possibly cut it if you have the reverse modual but other than that you're good
the lug
My bosses CEN GST 7.7 kept doing that also. here is a Hitec servo horn. It is double sided, but it is stronger than the single sided Hitec horn. I just cut one side off. It is made to work with Hitec servos, so you won't need any plastic adapters that will strip out.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCRT6&P=7
IL
Thanks for all the help everyone. Yea I am sure I used the right servo horn." they were leftovers from my TH servo on my Trex 600." I do have a servo saver on it and tonight I picked up an aluminum horn from my LHS to try out and see if it holds. Thanks again everyone
OH
ORIGINAL: stussman
That sux... yor wife being into rc
ORIGINAL: PrjctStrtFrce
That's hot...you're wife being into R/C cars...[8D]
I LOVE having nothing in common with the women I date...because it gives us things to discuss and learn from each other:P
Plus it makes for better
yeah
But, seriously...I don't think I'd be able to handle that.
OH
ORIGINAL: freeflyn2001
I wouldn't put a Mach 427 in a heli, and I wouldn't put a heli .46 in my Savage.
A helicopter's servo horns are NOT designed for the loads and impacts a 12 lb monster truck can put on them.
IL
ORIGINAL: ThunderbirdJunkie
Well DUH. There IS such a thing as using a proper part for the application.
Sounds like you have the servo saver set too tight. I bash harder than probably 90% of people, and I have been running the same plastic servo horn since I installed my cam type servo saver in 2005.
OH
Like I said in the beginning of this post. I am new to this. Any anyway the Servo horn I used was off a Hitec servo HS 5625 that can also be used for a Truck steering servo. The servo I have on the steering HS 645 is only running 24 in oz more of torque.
Servo saver set too tight will destroy the servo in this situation, not the horn. I've been running the same servo horn on my truck since it was new 2 1/2 years ago and only God knows how many gallons (my Mach 427 is on its last legs...I'm thinkin 13? 14 gallons? considering what kinda life I got out of my last 6 port SH motor)
Remember, we ARE talking about using the throttle linkage from Airwolf as a steering component in Bigfoot.
