Keep busting diffs and bevel!!!!!
IN
Alright, almost everytime out i keep busting diffs or the bevel gear, this one lasted 2 tanks??? i have 3 speed, 15 tooth bell, 47 spur, 40 series crimefighters. I have checked the slipper a thousand times!!!! Any ideas??
RE: Keep busting diffs and bevel!!!!!
Are the bearing seated properly in the bulk head? Also are you letting off the gas when landing after a jump? Everything shimmed up properly in the diff? Finally any damage to the pinion gear (look close). Oiled or greased up good in the diff? Just a few thoughts.
IN
yeah seated right, i dont even have to be jumping, this time today i was runnung on flat ground, in short fresh cut grass and busted the rear. I have ran with little grease, alot of grease, even no grease with the same result. i looked at the pinion and ring gear It is the pinion (bevelgear), that i break the most. Bevel gear stock part # 86031
Ok that gear, that's the one I refered to as the pinion gear. Now I had one of those go also, because the diff was running out of alignment due to one bearing on the diff wasn't seated in the bulk head properly causing that bearing to fail. After the bearing failed it was quick work before the pinion or bevel gear was toast. Make sure the bearings are in good shape and no exessive play when the bulk head is all buttoned up. Oh all the gears in the diff and on the diff have the word "bevel" in their name.
With a 3 speed and lightweight tires like the crimefighters, you should be able to run a 16 or 17 tooth clutch bell. The 15 tooth clutch bell will be giving you insane low end torque, which will put a lot of stress on your drive train. A larger clutch bell will smooth out the power delivery and prevent your engine from getting into it's peak power zone too early.
ORIGINAL: racefans26
no shims. they seem to ride on eachother great. not to tight not to loose, just like new..
IN
Yes front and rear... I have bought all new everytime. even just bought the whole diff assembly and with the same result. And Revo I just put that bell on today, that is the only one my LHS had in stock.. and the rest of the broken parts were with the stock bell and spur...
i think i dont know lol that is like set # 4 lol
UT
you might want to check your diff cases. if you have a striped screw it could be flexing under load and allowing the gears to slip. just a thought
well thanks guys...Got a whole new savy on the way tomorrow so we will see what happens!!!!!!!!!!
CA
I have never had any diff problems, and I dont want them of course. what I do want to know is what causes them to strip? from what I gather, if you land a jump with the throttle or brakes engaged.... then stuff is definitely going to break because of stress. Is there anything else from normal running and bashing that will strip diffs?
should i have diff grease/fluid in there?
IN
ORIGINAL: 02R6420
You bought a whole new savage because of a diff problem? I'll take the old one off your hands. lol
looks like you need #86922 HPI Machined Heavy Duty Bevel Gear
http://www3.towerhobbies.com/cgi-bin...?&I=LXTSY7&P=7
VT
i've never had any trouble with my diffs and i've landed many a time on power one one wheel then bounced around, going on and off power, and no failure here, maybe your carrier bearings are seiezed that happened to me once, but thats really odd
the lug
the lug
ORIGINAL: SAVAGEJIM
Oh yeah! I love the Cenchain (CEN) GST/Genesis/Nemesis diffs! They are thicker teeth and definitely tougher, but I have never taken the risk of trying to find out if the teeth wil strip when landing while gassing or braking. Too bad that all the Ebay chop shops charge an arm and leg for them; then never even offer a buy-out option so you have to bid-fight for them
I don't think the CEN ring and pinion teeth would fail in the case of a WOT landing. You would most likely break less durable drivetrain parts, such as the screw pins that attach the transmission output cups to the final drive gear shaft, or dogbones if you are running the stock pieces.
OH
what savy and motor are you busting diffs in, lets see a pic. of your setup, 40 series tires and rims are big and heavy your drivetrain may not be able to handle a dead stop to a wot
