Both Axial 28's All Sealed
RI
Just finnished sealing my brother inlaws Axial 28 spec1. Did my 28rr Earlier With help from budbud.He sent me exact pictures and a great write up on what to do..Came out clean not that clean matters..lol. and then the other pics are of the part behind the backplate, the right one with the grooves on it is the 28rr the other is the spec 1..Whats that all about?
RI
RE: Both Axial 28's All Sealed
Ok so I was on towerhobbies today and seen they carry axial 2xrr sleaves pistons and cranks. In the pics if u compare the. 28spec 1 to the RR. The RR has port work done on the speave and the shaft holder or what ever in the pics above is done and the shaft is pollished. So. Would the differnces in the extra work done on tthe RR tshow us that the RR would run different.hopefully faster and more power? What does these things add. I seen a lot of stuff on moding motor and what people are doing to mod htem its don't already to a smaller scale ims ure but there is a a lot of difference on the sleve ports. Check it out.
