owb keeps sliping
RI
owb keeps sliping
Ok my owb on my mt2ss ,18 motor keeps sliping. I took it out and cleaned it and made sure it was catching. After runing it for like 15 mins it stalled and the owb is sliping again. I even took off the back plate looked in and didn't see a lot of oil I wiped it out alil and sealed the backplate since it was open. I'm useing losi nitrotane fuel now don't know what the other owner used in it. Can I clean the inside of the motor with something that I could just spray in there to get what ever oil is in there. Wat else could cause this. The glow plug needs to be replaced cause it stalls when I acelerate and then let off and tap the bbrake
TX
RE: owb keeps sliping
ORIGINAL: hghflyrjd1
As for the OWB, for the twentieth time, what fuel are you running? High lube fuels cause your OWB to slip constantly...
RI
I use losi sport. But I think the previus owner used traxxas which is high in oil content. How can I clean out the motor so it won't happen as often. I'm gonna use the losi fuel. I didn't think it could happen so fast after cleaning it and running half a tank
