X, XL,and FLUX Parts Comparison
RI
I ran across this thread in another forum. Was just wondering if anyone else has seen this.Its not my info but usefull maybe someone can edit it and make a sticky or another thread. Thanks. Give it a Look.
http://e-savage.com/forums/showthread.php?threadid=4638
RI
RE: X, XL,and FLUX Parts Comparison
Yea I already have the flux diff gears and I'm looking to upgrade my X cups to the flux SUPER heavy duty ones.
short history about that site, it use to be the first ever site for the orig e-zilla, then when hpi took the name it turned into the e-savage forums, then after a long period hpi took it over and made it an official hpi forum for the e-savage.
So i doubt it will get stickied but one of if not the best E-Savage forums.
its not sticky worthy, for one its a link to another forum which is in the rcu rules of things not allowed, and its not content posted on rcu, if he comes and makes the same thread here then it would be able to apply for stick worthy.
if anything a thread that had mega hpi links, like links to the latest bb video, how to brake in the motor, etc...
all in relation to hpi, kinda a thread to look for on a go to guid, for example, wondering where you saw that how to thread look in this mega link thread under how to threads and wamo there it is, it would clean up a lot posts two cause people could go to that read up on things and help them out instead of asking the same Q multiple times a day in a different format but none the less same question.
If I had seen this 4 days ao, I would have just bought XL bones and stub axles and had the extra width, instead I just bought X 4.6 stub axles, I guess you live and learn...
RI
Well, like I said it not my info BUT I KNEW it would be well used info none the less. It would be nice to see it here for others to easily get to. Someone should edit it somehow so we can use it and still give the credit to the hommie that wrote it up. Just a thought. But I am gonna convert my drive train to flux status
ON, CANADA
Its a great reference either regardless of where its coming from.. Helps out alot of the Pre-XL users here that want to upgrade or purchase replacement parts..
If its against rules, so be it.. Bookmark it for yourself.
RI
Yes the flux pinion and ring gears are SUPER heavy duty as well as all the cups and axle dogbones but I'm sure u would need the cups to fit the dogbones
RI
Yes I have my X pinnion and ring gear upgraded to flux gears looking to do the cups and dogbones soon. Have u had issues with the XLs diff gears breaking or anything just to get an idea how strong they are. I'm sure the XL gears are a lot stronger then the X gears since they are machined
Good Day,
I've been out of the Savage Realm for 2 years already since I sold my Savage X SS.
I plan to buy the Savage Flux this year but I still wanted to make use of the Nitro engine on occasion. Is there a way for me to bolt a Nitro Engine using the default Savage Flux Chassis or there are several parts that needs to be purchased.
I checked the link [link=http://e-savage.com/forums/showthread.php?threadid=4638]X, XL,and FLUX Parts Comparison[/link] and it was very helpful but I just need to know Flux Chassis' compatibility for Nitro Engines.
Carl
Carl
CA
It's probably harder to take the electric to nitro route than the nitro to electric. The Flux has a lot of different parts. The most important part is the center gearbox. I don't think the Flux center box is set up for a braking system. I would also imagine mounting the fuel tank would be awkward because the nitro X has part of the chassis cut out for the tank. Those are the two main issues that I've noticed.
I currently own a Savage X SS and I've been tinkering with the idea of installing an electric system. Like I mentioned earlier, it's easier to take the nitro to electric route. All I need is a motor mount and battery trays.
There are two ways I can convert to electric. The least costly and invasive route would be to purchase Kyosho Twin Force battery trays and a Kersaw Designs motor mount. I don't have to heavily alter my X, which allows me to easily revert to my nitro powerplant.
The more costly and invasive route would be to purchase the Flux chassis plates, battery boxes, and motor mount.
If money isn't an issue, I would just buy the Flux and a nitro MT.
