wobbley tire FOAM BLOWN
RI
I just broke in my new axial 28rr and no when I'm doing some high speed runsim noticed the wheballons way to much. Then I squeezed the tire and noticed an area in the tire that has no foam behind it. I don't ever drive it through water that I remember what can I do. Now ill have to replace tire just to get the foam replaced?
RE: wobbley tire FOAM BLOWN
ORIGINAL: hghflyrjd1
Have the same problem with my stock terra pins om my xl. I trird the massaging ting and that didnt help so i put it on the rear of the truck, it was the front before, in the hopes that the more concestent traction would help even it out. Got a little better but havent run it much since so we shall see.
The only problem I have had with the Terra Pins so far is they like to bend to the inside and not fully return. Looks kind of funny. Happens mostly after driving in a circle really hard. kind of bends them inward.
