Weird Savage X problem
AB, CANADA
Hello everyone,
I am new to the forum, and to the RC world. I recently bought a Savage X 4.6 truck, which I absolutely love. I decided to change to a racing clutchbell and steel spur gear. After I set my mesh. I started the truck to test it quick. The weird thing is that when I pulled the throttle on my radio, the truck didn't move. When I moved my throttle forward to the brake position, my truck moved forward. I have no idea what I did wrong. Does anyone have any ideas on this? I tried to search the forums but couldn't find anything related to this.
AB, CANADA
RE: Weird Savage X problem
Would that cause this even if I don't have a reverse module in my Savage? Sorry for my ignorance, but like I said, I am a newbie to all of this.
WA
ORIGINAL: jshel-canada
Hello everyone,
Hello everyone,
Or i could just be joking. [sm=biggrin.gif] What Lug said is probably what happened
VT
the lug
ORIGINAL: rclugnut10
its on your TX, i'm right next to the power LED there's two slide switches that are kinda set into the body or the remote change the position of the one labled throttle or ch2. and that should fix your problem
the lug
the lug
Remember when I was at the LHS looking for parts (one of the many bin dives) and a guy came in wanting to buy a Spectrum cause his controller was "busted", because it was braking when he hit throttle. Clerk flipped the switch and said go home
AB, CANADA
the lug
the lug
NS, CANADA
You know, as likely as it is that he just needs to hit his Servo Reverse switch, I've never had one change to the wrong position all by itself. He must have taken the engine out to change the CB, and that means disconnecting some stuff. I wonder if he got his intermediate bellcrank back on is some odd postion where it reverses the throw. Not even sure if that's possible wihout looking....I'd have as much luck trying to figure out the solution to a Rubic's Cube in my head. Anyway, the point is, maybe he should "also" be looking at what he dismantled and check to see if he put it back together correctly. But "yes", it's probably that switch...........
AB, CANADA
Sorry for my ignorance, but what is the bellcrank? I will try the switch tonight, if thatdoesn'twork, I will take it apart again to see if I screwed something up. I have to put lock-tite on the screw for the clutchbell anyway, which I forgot to do previously.
ORIGINAL: Argess
NS, CANADA
The bellcrank I"m speaking about is the little black plastic thing that rotates when you operate the throttle. It is located near the fuel tank. The linkage from the engine carb fastens to it, as well as the linkage from the throttle servo.
AB, CANADA
ORIGINAL: Argess
