Help to ID noise on Savage
AL
Hey guys, I've decided not to sell my newly assembled Savage (great choice right? lol) and get it broke in and running hopefully over this coming week. But tonight when I was looking over things, I hooked up my freshly charged 6v 3000mah hump pack and was just rolling it around by hand on the floor and turning the wheels and trying to lock up the brakes. This is where I noticed my potential problem (at least I hope not):
When rolling it along quickly by hand and then applying full brake instantly, I am hearing a sound that almost sounds like some type of grinding. When rolling it around and gradually applying the brakes I don't get the noise, but when going to 100% brake very fast the noise can be heard.
Any ideas on what may be casing this? I bought it a month or so back form a reputable seller on here and the only things I have done to it are add my own TX/RX & battery and installed (but not yet broke in) the Axial .32. If anyone can help it would be greatly appreciated. Thanks
-Mike
-Mike
RE: Help to ID noise on Savage
it only does it when you brake? sounds to me like a brake problem then, does it have metal discs, are the pads worn are corodded and need cleaning up with a good run? my traxxas slayer does that if it was wet the last time i had it out the disc corrodes and makes a noise, a run alwys sorts it out
I had a similar thing, is it a sort of clicking grinding noise? If so check the brake assembly, the hex that slots through the centre of the brake disk had, a groove worn through the corners so that under heavy braking the disk slips round instead of slowing the drive train
AL
ORIGINAL: claccytim
I just bought the dual metal disk set, which comes with a metal hex to replace the worn plastc one
actually come to think of it the conversion comes with a flat sided drive cup, which gives a much better contact between the disk and drive input to the tranny
AL
ORIGINAL: claccytim
Hmm, what could this noise be?
AL
ORIGINAL: claccytim
in your first post, you said newly assembled, is this a new truck, or second hand?
ok, does it feel at all notchy when you roll the truck by hand? if so it may be worth checking the diffs, as on the earlier models, the bevel gear on the input shaft inside the diffs have a habit of losing teeth
AL
ORIGINAL: claccytim
I hope it's not the diff, as the guy I bought it from had good ratings and said it ran fine and was in good mechanical shape...
AL
Here's the link to the video...not the best quality due to going from my cell phone, but hopefully you can get an idea:
www.youtube.com/watch
sorry to say it, but that does sound like teeth jumping to me, check the diffs to be safe, as if you run it like that you may damage more gears,
AL
ORIGINAL: claccytim
ORIGINAL: md7989
Well crap, so how in depth is it to get to the diffs? I've got the manual with all of the exploded parts views...dang, so I assume that means having to take out the motor, pull of the chassis plates, etc., etc. then right? lol
ORIGINAL: claccytim
The only time you have to pull off a TVP is if you have the older Savages (Pre-Savage-X)
QC, CANADA
ORIGINAL: SAVAGEJIM
You do not have to pull off the engine of TVP plates. You only have to dismount 6 screws and pull out the removable half of the diff housing to get the diff out.
ORIGINAL: md7989
ORIGINAL: claccytim
NV
i was gonna recomend to check your diffs it might be a bad gear or gears or the lash may not be set right hopefully this helps i had a mammoth and tmaxx that ahd the same noise on the mammoth it was gear lash and on the maxx it was a bad spider gear good luck
AL
Hey guys, news update!!! So I torn off everything I needed to get a view of the pinion and ring gears in both diffs and they are fine...however, the rear driveshaft from the tranny to the rear diff seems to be too short, as I started spinning the rear tires very fast by hand and hit the brakes and noticed that the shaft came out of its cup on the tranny end...here's some pics:
Can you guys explain how I might be able to fix this? The noise definitely came from this shaft like this.
1 fix for this would be to takethe shaft out, cut 2 lengths of fuel tubing to about 5 mm in length, and place 1 piece in each drive cup before reassembly, this will space the shaft and keep it more central.to be honest, i have done this to all of my drivecups, simply to remove slop, and reduce wear
AL
Thanks, I will try that this evening.
ORIGINAL: claccytim
AL
Well I tried the fuel line on the ends of the driveshafts and it helped with the slop in them, but I've now narrowed down that the noise is coming from the transmission...what do you guys think is going on inside there for it to make this noise?
The diffs are freshly greased up and spin super smooth when the shafts are out and no teeth in the diffs are missing.
How much would a new transmission cost? Or a rebuild kit?
QC, CANADA
ORIGINAL: md7989
i have a similar noise coming from my savage ss 4.6 and it seems that after checking it over piece by piece that nothing is broken or worn, i think is just a normal noise on the older savages. the only difference is that under 100% braking the wheels on my car just stop (which is ok 'cos the tyres are quite skiddy) but the noise is only under almost full braking.
I have the SAME exact issue. I pulled the front diff out and drove it... slammed the brakes and silence....from what I understand is that we need to shim the diff . Use google to do a search and you find the how to...
