Clutch activation
So i just got a Firestorm 10T truck and i started trying to tune the engine because it always stalled, i adjusted the idling needl, and it stopped stalling. Came another problem, it engages the clutch, even without any throttle, so can only be stopped if i pull the brakes and don't let it go. Can somebody help me, how to adjust everything so it doesn't stall but stays still when off throttle?
petersen (12-31-2024)
So i did set everything back to factory, and it didn't stall, but still wouldn't stay still without throttle. I brought it out to an empty car park to see its full potential, but the brakes failed partially and i broke the parts of the front bulkhead set (100319), the brakes does work somehow but they aren't strong enough to stop the car.
Was the truth purchased new or used?
Ok I was just wondering because there are several things to consider if an engine is new or used. Are you comfortable with removing the engine from the truck? I don’t know what your mechanical abilities are and what tools you have so that’s why I ask.
Anytime a used RC especially nitro is purchased a good tear down is a really good idea. The engine should be taken out, cleaned externally then tear down, inspected, cleaned internally with rubbing alcohol and ad a few drops of after run to the engine bearings then reassemble and make sure all the seals are good. There are several reasons for this as there could be a bad gasket seal or a bad one way bearing in the pull start causing a lean running engine, ( a bad front engine bearing can cause this as well). Also there could be a bad clutch spring or something broken in w/ the clutch causing it to engage prematurely. It’s also a good idea to tear the whole truck down for the same reasons and that way you can familiarize yourself with the truck and how everything works.
well thank you, but i don't really have an idea how to do all that, and i also might not have the tools for it, is there any help for this somewhere, i really wouldn't take the whole truck apart if i don't know what im doing
i learnt the basics of tuning already so thats why im here, because first i thought that was the problem but it should be good for tuning now. I do have a hobbyshop not so far so i will turn to them next, thanks for all the help
Well I hope you get it sorted out and keep us informed.
In post 3 you said it was stalling when you "don't give it throttle / under braking". Have you set your idle stop? If you don't do that it'll kill your motor every time you hit the brakes.
