Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Plane Scaleing
Old 01-19-2005 | 06:24 PM
Default Plane Scaleing
Does anyone know how to cahnge teh size of the planes? i can change theW/S but not the chord, and i can't change teh fuse length, can anyone help me?
Old 01-20-2005 | 04:29 AM
Default RE: Plane Scaleing
Hi,
find a program for scaling at Rainer's homepage:
http://home.arcor.de/rainerstein/afp/index.htm
It's called ZoomTool.
Attention:
This only scales the OBJ file, the geometry!
The TMD will most probably not work any more!
You have to use a text editor to adjust the joint points of aircraft parts, the rotation axis of moving parts, the weight of single parts, the forces and dampers for the joints and so on.
Even with a good knowledge of TMD this takes some hours until you finish your new scaled model with a new setup.
Regards
Rodeo
www.rodeo.onlinehome.de
