Chip's Ultimate
My Feedback: (7)
Can someone please tell me how to change the sound of Chip's Ultimate (downloaded from AFPD site) from something that sounds like a full scale Cessna to what a 3W or DA sounds like. The plane is fantastic but the sound is horrible. (I've been to TOC twice and his sounds nothing like the AFPD model). Even the 330's sound would be better than what's playing now.
OR
Might try searching for a new "wav" sound file online?
http://www.simviation.com/fsdsounds.htm one location some sound files can be located.
OR
http://www.netwings.org/library/CFS3_Sounds/ Looks interesting.
http://www.fsplanet.com/29102003.htm may also be a possible source.
But the sound files I have seen look very large.
They may not be usable, I don't know.
Have you heard and/or considered trying; Piper J3-Cub.wav, Corsair.wav, or Do28.wav ?
My Feedback: (7)
Ok, I've tried to post the extra 330s sound by copying it to the ulti, but there are three different sounds for the extra->1710, 3510 & 5730. I figure these are RPM's and the wav.file takes these and uses each one depending on where the stick is at the time. But when I rename these under "Ulti-1710, etc, only the 1710 plays, not the 3510 & 5730. In other words, when I run the Ultimate, the sound is the 1710 sound sounding VERY slow when at idle and at 1710 rpm when at full throttle. There's got to be some kind of setup to allow all three sounds for the ultimate. Thanks in advance!
