Glider Towing
So, how do I get the glider towing function to work ?
I have the P40 tow selected as aircraft 1 and one of the gliders as aircraft 2. Plane 1 is controlled through the dongle using a Futaba skysport 4 and the glider is controlled via a USB joystick.
Split screen is selected, and I choose *Glider Tow*, *Start Towing Glider* from the menu. It repositions the aircraft for me ready to tow, but no tow line appears between the two aircraft and the glider can't be towed.
Am I missing the obvious ?
Any help would be much appreciated. Thanks,
Tim
Tim
Hi Greg,
Was just coming back to tell you all that I have now R.T.F.M. !!! and noticed that the tow release for the joystick was reversed.
Everything is fine now.
Tim
Tim
