Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
AFPD planes to AFP
Old 11-28-2005 | 05:26 PM
Default AFPD planes to AFP
how do you convert an AFPD plane so that you can use it in AFP? thanks in advance.
cary
Old 11-28-2005 | 09:14 PM
Fly-guy's Avatar
Default RE: AFPD planes to AFP
Hey cary,
There are two different ways to DL planes for AFPD.
1) they come as a .exe file. These need to be extracted with a program like WinRAR which can be downloaded for free, just Google it.
2) They are in a zip file which is simply unzipped.
Once you have done either of those open the folder and find the .tmd file of the aircraft you just DLed. Right click it and open with Microsoft Word. At the top of the 1st page you will see the folloing lines;
// aerofly professional --------------------------------------------------------
// file: su31b.tmd
// version: 1.6.0 these numbers may differ from plane to plane
// type: 17also may differ
// lock: 0
The two lines that I have said may differ need to be changed for the plane to work in AFP.
I change the lines to;
// file: su31b.tmd
// version: 1.2.0
// type: 1
// lock: 0
This should now work.
Now you need to make sure the plane uses a sound file you have availale.
Press Ctrl+F to bring up the find option. Search for sound.
You will see lines a follows;
Sound0File = "g15-3000"
Sound1File = "g15-5000"
Sound2File = "g15-10000"
Sound0RPM = 3008.2
Sound1RPM = 5270.4
Sound2RPM = 10202.7
Sound01RPM = 4000
Sound12RPM = 7000
cd ../
The first 3 lines are the sound file used. Make sure the file listed is in the sound folder.
If not change it to one you do have.
Once you have made these changes it should work.
I do find sometimes AFPD planes do not have a working skin and appear as all white. They still fly the same just all white.
Fly-guy
EDIT: Spelling
Old 11-29-2005 | 07:35 AM
ALMA's Avatar
Hmm, Time that dion begins a FAQ here........[:-]
