AFPD Upgrade Questions
I'm thinking about upgrading from AFP to AFPD and have a couple questions I haven't been able to find answers to in this forum. Could someone help? They are:
1) Will my old serial Game Commander controller from AFP work with AFPD? I assume that as long as the USB cable is plugged in, the serial controller will still work, right?
2) I've got hundreds of models I've downloaded and installed in AFP--will those same models work in AFPD? Or are AFP models incompatible with AFPD?
Thanks!
Thanks!
I'm not an expert, but I would think you are OK on both fronts. As far as the controller goes, I think it is simply a piece of hardware, like your keyboard. So it should be universal. I am only guessing on the planes though. If you can give me a link I will download one and try it in AFPD.
