Game Commander dying!!!
Oh well, I think I've finally worn out my Game Commander[X(]
I cannot calibrate the throttle to it's maximum & minimum settings, and now the aileron control is starting to get as bad[>:]
I tried re-installing AFPD with no difference, so I'm sure it's the controller that's at fault.
Does anyone know if I can get replacement parts for the GC?... if so, who do I contact in the UK?
By the way, I don't think warranty would be an option as I bought the AFPD with GC second hand...
Thanks in advance,
Tony.
Thanks in advance,
Tony.
Tony, just contact Ikarus and ask. You never know, they may still cover it. Another option is get a SimBlaster cable and use your own tx. The game commander (assuming you have the USB version with built in interface circuit) would still need to be plugged in always for the software to run.
Hi Mike,
Many thanks for your reply
I will contact Ikarus USA, as I can't find any info for Ikarus in the UK, and see what direction they point me in.
If they cannot sort anything out, then yes, my only other option is a lead to connect my transmitter to as the AFPD is barely usable with the GC in it's current state.
Once again, thanks for your help and I will let you know how it goes.
Tony.
Tony.
