Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software > Ikarus Aerofly flight simulators
 New patch for AFPD add-on users Version 1.9.7.11 >
Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Old 11-22-2006 | 08:53 PM
rajul's Avatar
Moderator
My Feedback: (58)
Default New patch for AFPD add-on users Version 1.9.7.11
Ipacs has released a patch for AFPD users with Add-on 1 and/or Starflight add-on. You may download the patch from http://www.aerofly.de/www/downloads.html This patch addresses the following issues:
-Fixes a problem with the aircraft reflection
-Keys ‘7’ and ‘8’ allow the change of thermal wind speed during simulation
Please install the patch after you have installed the add-on disk
To keep all your settings, make a backup copy of your config folder. The config folder is located in C:\Program Files\IPACS\AeroFly Professional Deluxe\config After installing the patch, you can copy back your config folder into the same location. If you're using your own Tx, re-calibrate it.
(NOTE: For AFPD users without any add-on, please download and install patch 1.8.0.25)
Enjoy!
Old 01-03-2007 | 10:01 AM
Default RE: New patch for AFPD add-on users Version 1.9.7.9
There is still a problem in that it is not possible to move (reposition) the window on the monitor. In the past I was able to move the AFPD window to my 37" LCD in the extended view mode. I use Windows XP. How do I let Ikarus know of the problem?
AL
Old 01-03-2007 | 10:43 AM
rajul's Avatar
Moderator
My Feedback: (58)
Al, can you elaborate a little? Are you using two monitors? How do you connect them? Which version of AFPD worked in this monitor configuration, and which version do you have now?
Old 01-03-2007 | 04:37 PM
Mike, I have a laptop that I connect to my TV which is a 37" LCD and setting the LCD to VGA. So I use the TV as an extended screen to my laptop. Berfore I bought the Starlight upgrade I was able to drag the AFPD to the extended screen (the TV) and resize the AFPD window to fill the TV screen. After I bought Starlight and did the upgrade I was not able to resize or move the window. After the last upgrade to 1.9.7.9 I can resize the AFPD window but I can't relocate it on the laptop or move it to the TV.
As a point of information I have been able to move my browser window to the TV and resize it. I have also managed to do it with Mapsource by Garmin.
Thanks for the help and let me know if I can answer any other questions.
AL
Old 01-03-2007 | 08:03 PM
rajul's Avatar
Moderator
My Feedback: (58)
Al, I assume you're using the tvout of your graphics card. Did you try to update your video card driver and BIOS as well? You could also try making the LCD as the primary monitor. Remember to tick the box to extend the windows desktop in your display properties menu
Old 01-03-2007 | 08:48 PM
Mike, it does work to change the TV to the Primary display and then AFPD is on the TV. But why can I leave it as the secondary and all of my other programs can be dragged to it. I think that there is still a bug in AFPD.
Thanks for the help and I hope they fix the bug.
AL
Old 01-03-2007 | 09:01 PM
rajul's Avatar
Moderator
My Feedback: (58)
Al, I haven't had the chance to verify this, but I'll send a note to IPACS. If you do find a solution, let us know.
Old 01-04-2007 | 07:15 AM
rajul's Avatar
Moderator
My Feedback: (58)
Al, I would like you to try this. Go to your control panel->display->appearance. Change the windows style from xp to classic. Pls report back if you can do the dragging. Thx
Old 01-04-2007 | 09:22 AM
Mike, I tried changing to Classic and it didn't work in that mode either. I look forward to see if Ikarus can fix this as one of the things I do at my office is putting it on a 15 foot screen with a LCD projector. That is really like being at the flying field and fixing this bug would make it easier to do.
Thanks again,
AL
Old 01-04-2007 | 09:33 AM
rajul's Avatar
Moderator
My Feedback: (58)
Al, this will be taken care of in the next patch from IPACS. Email or PM me your email address, and I'll see if I can send you a temporary patch.
Old 01-22-2007 | 09:40 PM
My Feedback: (9)
Mike, I just installed Starflight add on disc to AFDP and the first thing I did was to download and installe the patch from the website but I noticed the patch didnt have the same revision number I assumed it was an up to date patch (It said it was for Starflight).The installer said it succesfully installed Starflight I did not run the program before I loaded the patch and I also got a message that it was succesful. I then started the program and
the graphics and performance are awesome.
I have a problem though when I exited the program my PC crashed and I got a bunch of vertical lines on my screen and nothing would allow me to close the program so I turned off the power and rebooted.
and then If you can help me with this problem it would be great because this sim is too much fun I gotta run it I love the P51! I did not reboot the PC after installing the Starflight Disc and the Update patch I just went and flew the Mustang, was that the problem should I have rebooted the machine after the upgrades(You probably remember me you helped me out on the phone)
Thanks Much Joe
Old 01-22-2007 | 10:06 PM
rajul's Avatar
Moderator
My Feedback: (58)
Joe, when you start up AFPD, what is the revision number you see on the top right corner of the main menu? Which patch did you install?
Old 01-22-2007 | 10:39 PM
My Feedback: (9)
Mike, I downloaded patch# 1.9.7.9 and the version number thats in the top right hand of the screen is 1.9.7.3
However all I needed to do was to reboot the PC and its all good I am a happy guy I started and ended the program 3 times(Not Reboot just open and close the program) after the initial boot and it WORKS KILLER beats the hell out of RF.
Mike please dont tell me I installed the wrong patch[X(] It was the only one that said it was for Starflight, now I did go onto a different website just now thats in both English/German On the page 1.9.7.9 had a later date 12/06 and it was for Starflight so I downloaded but it works and I love it.
Thanks Mike
Joe
Old 01-22-2007 | 11:28 PM
rajul's Avatar
Moderator
My Feedback: (58)
1.9.7.9. is the latest patch and you have it working already. Enjoy!
Old 01-22-2007 | 11:34 PM
My Feedback: (9)
Yep its cool
Thanks Mike for all your help and I am glad I installed the correct patch
Now I just need to get my Stylus up and running,
Thanks Joe
Old 01-29-2007 | 09:20 PM
rcflyer04's Avatar
Mike,
I am interested in the patch or the temp. patch because I have the same setup with windows XP , and I use my HDTV as a 2 nd monitor,
Did you have any luck trying the temp patch with graywolf?
Dan
Old 01-29-2007 | 10:03 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi Dan, IPACS is aware about the issue and this will be probably incorporated in the next patch. The latest patch 1.9.7.11 was developed before the issue was reported. The patch sent to graywolf was 1.9.7.11 and it did not work with his setup. I understand that the previous patch 1.9.7.9 was OK, so if you're using this version, you might want to hang on to it.
Old 01-30-2007 | 06:34 PM
rcflyer04's Avatar
Thanks Mike,
Dan
Old 02-10-2007 | 08:06 AM
Default RE: New patch for AFPD add-on users Version 1.9.7.11
On your note about downloading the Add-On patch 1.8.0.25 ,[ for those who have the old 1.8.0.21 ] we encounter a flash note from the site [ quote ] TYhe Package has been corrupted and will close,please try to obtain an original copy . ????? we are attempting to obtain some aircraft and when downloading the file from IPACS ,they will not appair in the aircraft selection ,even that they are in the aircraft folder ???? HELP -----Flyer Lost ????
ORIGINAL: rajul
Enjoy!
Old 02-13-2007 | 06:14 PM
rajul's Avatar
Moderator
My Feedback: (58)
Your downloaded patch could be corrupted. Try to redownload the patch and reinstall again
