Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
AFPD with Geforce 5700
Old 01-07-2007 | 01:03 AM
Default AFPD with Geforce 5700
Hello
I am thinking to buy a Ge force 5700 card for my AFPD is this card OK of for 1024 resolution will i get good FPS(Frames per second), i cant afford high performance cards they are too expensive.
highfly
Old 01-07-2007 | 06:21 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: AFPD with Geforce 5700
The 5700 should work fine for AFPD. Remember to install the latest Nvidia driver. Here's a good price/performance guide from Tom's Hardware http://www.tomshardware.com/2006/12/...for_the_money/
Old 01-07-2007 | 11:31 AM
How would a GeForce 128 mb graphic card work with the AFPD, the 5700 is a 128 mb not 256 i need your advice before i buy it, my friend has AFPD i have AFP will the old cable of AFP work for AFPD if i use a USB converter to the serial port connection.
Highfly
Old 01-07-2007 | 05:20 PM
rajul's Avatar
Moderator
My Feedback: (58)
What are the specifications of the computer you plan to use? Sounds like an older PC with no usb ports? Also, have you considered upgrading your AFP to AFPD?
Old 01-08-2007 | 12:49 AM
Hello rajul
The only thing i found great about the AFPD is the plane look really real, may be some physics also, but can you tell me what the real diffrence between the AFP and the AFPD., and also i want to thank IPACS who created AFP from the bottom of my heart because it has taught me lot many things, today just because of AFP i am practicing IMAC style flying and also 3D, my cousin gifted me AFP in 2004 since than i am practicing and today i can say i have become a pro. i will upload some of my flying on youtube soon. Iam more into precession aerobatics but i also like 3D, my all time favourite pilot is Somenzini. I cant afford IMAC planes right now but will soon get one. I genrally practice advanced and unlimited sequences on AFP, For Flying AFP is GOD for me and its absolutlely great.
Highfly3D.
Old 01-08-2007 | 02:25 AM
rajul's Avatar
Moderator
My Feedback: (58)
Highfly3d,
AFP has a lower system requirement compared to AFPD.
The recommended system requirement for AFP is:
- Intel Pentium II compatible processor with at least 700 MHz or
- AMD Athlon compatible processor with at least 700 MHz
- OpenGL compatible graphic card with at least 32 MB
- 128 MB RAM
Compare this with the recommended system requirement for AFPD:
- Pentium 4 with 2.0 Ghz or
- AMD 64 with 1.6 Ghz
- 256 MB RAM
- OpenGL compatible 3D-graphics card with 128 MB (256MB are only required if using AeroFly with full antialiasing and very high monitor resolutions)
The 5700 will work with both AFP and AFPD
Here's a non-exhaustive comparison between AFPD and AFP:
Models:
- Flight physics improved.
- Higly detailed new models, which are not available for AFP
- Light weight aircrafts (foamies like shockflyer) and helicopters (piccolo) now work correctly.
- Left turning rotor systems for helicopters added.
- More than 4 rotorblades supported.
- Dual head helicopters supported.
- Smoke now supported for 2 models.
- Model surface reflections can be switched on/off.
- Glider sound added.
- 4D models with PPS (push-pull-propeller-system or VPP).
Sceneries:
- Besides the 3D sceneries, a new panorama (photorealistic) scenery function has been added
Sound:
- Background music can be switched on/off.
- mpeg music clips can be loaded.
Handling:
- Large preview image and preview text added to model selection menu.
- Help text added to main menu.
- USB cable instead of serial cable.
- Improved interface for easy/advanced transmitter setup.
- High quality screenshots and video can be saved, number not limited.
Free downloads:
- All the newer free models and sceneries are only developed for AFPD.
Hope this helps.
Old 01-08-2007 | 01:06 PM
My Feedback: (25)
I am running AFPD on a 4 year old G Force 4400 card.Holds 60 fps with the V sync on and running all graphics.That 5700 should do just fine.
Old 01-09-2007 | 11:55 AM
Hello
I checked the local computer shop for Graphic card, i found out the Fx5200 series, 128MB will this card be enough for the AFPD, any advice if any one has this card.
high.
Old 01-09-2007 | 06:41 PM
rajul's Avatar
Moderator
My Feedback: (58)
With the 5200 series, some model/scenery combinations might not run fast enough
Old 01-10-2007 | 01:54 AM
Hello Mark.
But what is the ideal or say standard FPS which will give the real feel of flying in AFPD, is it 60 FPS and above, some say they get 200 FPS or 300 FPS. as far as my AFP i know it says 60 FPS and above. What do you say.
Highfly3D.
Old 01-10-2007 | 02:23 AM
rajul's Avatar
Moderator
My Feedback: (58)
Yes, I think minimum is about 50-60 FPS
