Installation procedure for AFPD model downloads
#51
IA
RE: Installation procedure for AFPD model downloads
The version on my original says Version 1.8.0.9. Ive had it for years. Wish I could start all over with a fresh disk and the TX is comes with. (I use lots of batteries up in my Eclipse 7) LOL.
This version is running perfectly on my Laptop right now, except for a square for a shadow!
My desktop video card is a Vision Tek Radeon X1300 series, and I'm running 4 gig of ram with readyboost, and a 2.7 GHZ Pentium duo Core.
It had been working perfectly on that card. Did you watch the video in the link above "My aerofly heli leans"? That shows how well it was working.
Thanks again,
Dave.
Thanks again,
Dave.
#53
IA
Vista was installed as a fresh install.
The program is in Program files IPACS I don't remember disabling anything, and I don't remember putting any patches in.
Same with my Laptop. Just the original disk, and it is working...
What are the patches or updates called? I have a disk that I wrote on the words "Aerofly updates" from a couple of yeas ago. There are mostly planes on it. . I also wrote on it "do not install til after putting in the original version 18019, but I don't think I did that.
Sorry, the ole brain is getting old.
#54
Hi Dave, did you install Addon 5 into the same directory as AFPD? Did you download the license file and place it in the AFPD directory?
Pls email me your full name and address, and the serial number for your usb interface. Thx
#55
Hi Dave, I received your details.
The installation instructions in vista is here http://www.aerofly.com/ipacs_vista.pdf
When you uninstall AFPD pls follow the procedure given at the bottom of this page http://www.aerofly.com/www/downloads.html
#56
IA
I have tried to uninstall the Aerofly from the control panel. The install launcher keeps stopping it asking to check online for a solution,which is futile, so I cannot uninstall any of this.
If I delete the IPACS folder, I may still have remnants in my Windows. How should I proceed?
It seems that I have (in my ALL programs), Aerofly Pro deluxe , Aerofly Pro Deluxe (restored), Activate Addon 5 (using web interface), Aerofly Manual, and the Pro deluxe website. Nothing about uninstall.
#57
IA
Hi Mike,
I uninstalled and re-installed in a different folder. Then I ran the Aerofly 18019 Beta, I had on a second disk.
It is now running as per the way it used to.
Now, I am afraid to try and run that Addon disk 5 software I downloaded. Should I do something first? The download size was 942 mb. Does that sound right?
Dave
Dave
#59
IA
Okay, I wont install it. The The Beta disk is a patch I saved to the disk with a lot of extra airplanes, etc. When, I dont know, but it worked, is all I know.
Thanks.
Thanks.
#60
Dave, if you do not have any addons, the 1.8.0.25 patch is better http://www.ipacs.de/download/afpd18025.exe
You could download this and run it
#61
IA
Thanks.
I downloaded that and the program is running.. When you say download this and run it, does that mean the addon5? I should be able to run this same patch on my Laptop now, eh?
Thanks.
Thanks.
#64
IA
Okay, I just did the same thing to My laptop with that patch, but got the same message, so dont know if the patch actually worked. I assumed it did because at the end, it said, my Aerofly was updated.
But when I look at the numbers, they are still the same.
Window Popped up and said.
" The Package was unable to replace the following file:C:\programfiles\IPACS\AeroflyProfessionalDelu xe/AFPROD.exe"
Is is because I loaded it into a different folder, when I loaded it this time?
I can rename it back and try it, but think the patch found it anyway because it called the folder the same as the one I put it in when it asked where to put it.
#66
IA
WOW, Thanks very kindly for that. I really appreciate it.
I will let you know when I get it. Even though, it looks like that last patch above did not work, the addon should go in right or do I wait for your instructions. The first patch did work, it seems.
Thanks again,
Dave
Thanks again,
Dave
#67
Beaver DHC-2 problemms during the installation
- Version of apdf 1.8.0.9 , i modified the TMD file
- i don't have a Directory programme under the C:\
- During the startup of APDF only the loading of the DHC-2 but stay's in a black screen and after half minute loading error.
PLEASE who can help me , because i go build this plane in Depron and will have some skills in APDF
Rgds
Kurtie-Belgium
Rgds
Kurtie-Belgium
#69
WA
Hi, I am really enjoying downloading some of these new planes however I do not have a lot of available extra space. My question is how do I , or can I, get rid of some of the planes that came with my AFPD, which would make room for some of the others I would like to download? Any one have a step by step type of answer? Thank you
Steve
Steve
#70
I have AFPD 1.8.0.25
Ive downlod T-rex 500 from www.rc-sim.de
simulator dont want to download the model
#74
