AFD serial problems
My Feedback: (7)
MA
i just purchased this and it states that the interface was not found and i should search.nothing happened after search.what can i do?
it's plugged in to the serial port on the back of the CPU.
Angel
Angel
Moderator
My Feedback: (58)
Angel, ensure you have patch 1.6.8.6 installed and that the new COM port lies between COM1 and COM8. Also ensure that no other software is blocking your port. It will help if you disable any antivirus software when installing the main disk and patch. The sequence of installation is main disk, expansion pack (if you have it), patch
My Feedback: (7)
MA
Mike,i have installed the sequence correctly,when i open the hardware config. it does not see a controller on com1 but it does say that com1 is working correctly.
the Tx is on and i plug to the com1 in back of cpu,it does nothing,doesn't even notify of new hardware has been plugged in.
My Feedback: (7)
MA
ORIGINAL: rajul
Is your radio in PPM mode?
Also, please check your COM1 settings under device manager is as follows:
I/O range 03F8-03FF
IRQ 04
I/O range 03F8-03FF
IRQ 04
i'm using the EVO7 how do go to PPM mode on it?
but would that matter,isn't the comp supposed to see the interface anyways?
My Feedback: (7)
MA
how could i tell if theres something already using that com1 port?
when i went to the advance setting,it warned me not to change the comm number
Moderator
My Feedback: (58)
Accoriding to the tm.log Aerofly has NO RIGHTs to open either COM1 or COM2. This is usually caused by another program on the system that is blocking these ports. You have to disable the program first. You could also try to assign to COM3 to COM8.
