Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Aero fly cable question
Old 02-14-2007 | 10:23 PM
Default Aero fly cable question
I just got my Aero fly in the mail and I am having a ball with it. One thing though I thought was weird. I am using my JR radio along with the supplied cable. For some reason when I plug it all the way in it does not respond. But if I pull it one click out it works fine. Any ideas why it is doing this? Seems like it should go all the way in.
Maybe I need to reinstall the USB hardware again not sure. Also how do I go about doing that?
Old 02-14-2007 | 10:31 PM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: Aero fly cable question
Hi, for JR radios, you will need to get the JR adapter. The adapter goes between the usb cable and your radio.
Old 02-14-2007 | 11:53 PM
Oh okay. I miss understood when I ordered. I thought I needed the adapter if I was going to use Futaba. oops
Old 02-15-2007 | 01:24 AM
rajul's Avatar
Moderator
My Feedback: (58)
Either of these will work http://www.ikarus-modellbau.de/onlin...ca088.63839801 or http://www.fxaeromodels.com/product_...3394b887d3efa7
Old 02-15-2007 | 02:26 PM
I have about the same problem tukkus has.
I am using a JR 9303 with the Ikarus adapater cable.
I get a 'no tx signal detected"
Radio worked before, but Isent it to JR for repairs. They replaced an encoder board.
Anyway I also have Futaba 4 channel FM tx that works on AFPD with the Ikarus adapter cable ( Futaba) but only 4 channels).
My JR 9303 is on PPM mode, but still get a "no tx signal detecetd" though it does find the USB cable.
Any suggestions?
Thanks!
Ed
Old 02-15-2007 | 06:10 PM
rajul's Avatar
Moderator
My Feedback: (58)
Did the JR radio work with AFPD before you sent it for repairs? Have you tried another JR radio? It could be a bad internal connection in the radio itself. You'll need JR service to look at it again.
Old 02-15-2007 | 09:29 PM
AH I see. It came with that adapter but I did not have it plugged up. I just tried it out and its working fine now.
Thanks for the help!
Old 02-15-2007 | 09:36 PM
rajul's Avatar
Moderator
My Feedback: (58)
[sm=thumbup.gif] Great!
