Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Game Commander Problem
Old 05-29-2007 | 12:41 AM
Default Game Commander Problem
Just received my AFPD with Game Commander controller last week. The right stick is stuck in the down position. Is there a warranty on the Game Commander? Will I void such warranty if I open up the Game Commander and try to locate/fix the problem. Anyone else have this problem?
Old 05-29-2007 | 12:49 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: Game Commander Problem
Does the right stick move up/down in a ratchety movement? Are you a mode1 or mode2 flyer?
Old 05-29-2007 | 12:56 AM
Right stick (elevator) is stuck. Not ratchety, but stuck in up position (i.e. pulled back). Can't push it up for down elevator. I don't want to force it. Aileron stick motion (side to side) is OK.
Old 05-29-2007 | 01:10 AM
rajul's Avatar
Moderator
My Feedback: (58)
That's not normal. Can you remove the back cover (4 screws) and see if there is any obvious problem with the elevator gimbal mechanism? You may compare it with the other gimbals.
Old 05-29-2007 | 01:26 AM
OK, I got the back cover off and inspected the mechanism. There is what appears to be a pin that came loose and is sticking out from the gimbal? and is striking the mount. Pin is dead center on top of gimbal (i.e. the vertically rotating part).
Old 05-29-2007 | 01:39 AM
I can't get to the pin without removing the whole gimbal mechanism. Will removing the four screws in the front cover (at the right stick) allow removal of the gimbal mechanism?
Old 05-29-2007 | 05:35 AM
rajul's Avatar
Moderator
My Feedback: (58)
os, it looks like the gimbal centering mechanism is faulty. Please ship your usb game commander to the service department below with a brief description of your problem and daytime phone number. You may attach this thread for reference.
IKARUS-USA
Service Department
Billy Creek Commerce Center
5876 Enterprise Parkway
Ft. Myers, FL 33905
ph. 239-690-0003
fax 239-690-0028
Old 05-29-2007 | 11:47 AM
Thanks Mike. I will send the Game Commander in, as you suggested. BTW, love the AFPD, great graphics and choice of planes.
