AFPD can't find transmitter
OH
I just installed AFPD on my new computer and it says it has located the usb, but cannot find the transmitter. I did install the update patch. My new computer is running windows vista, i don't know if this makes any difference. But i haven't used the sim in a long time, and don't have another computer to try it on. I'm using the same transmitter that it worked with before. Is this a problem with the usb cord? I've tried two different transmitters.
OH
RE: AFPD can't find transmitter
I'm using a JR XF631 (which worked before) and I tried a futaba skysport. I don't think it's the radio because it worked with AFPD before. I installed the latest patch on the website.
NM
Just bought AFPD and have same problem. Program cannot find TX (JR XP6102). Am using JR micro connector. TX set to clear plane and on PPM. Get msg that I need open GL version 2.0 or better. Don't have Open GL as I have Dell Dim. E310. Has internal graphics card. Am I stumped.
Moderator
My Feedback: (58)
tbald, you need a GL-compatible 3D graphics card such as the ones listed here http://www.aerofly.com/www/requirements.html The integrated graphics card will not work. Please also take a look at the other system requirements
OR
I am having the same problem. I am running WinXPH and also running ReflexXTR, Realflight G4, and Aeroflypro Deluxe.
When I connect the dongle it is recognized, when I connect my T9CHP it is not recognized.
I have tried this before starting AFPD and after starting AFPD.
Once it worked for a min or two and then stopped working again!
OR
Thank you for trying.
My adapter is working fine, always has. I installed DirectX tried to install the most recent but it does not read that way. Then I reinstalled AFPD and applied all updates in consecutive order from the first to the most recent.
I connected the dongle and the Xmitter and they were recognized and functional. I then restarted the system and AFPD without the dongle and Xmitter connected, while the program was booting up I connected the dongle and Xmitter, the dongle was recognized but the xmitter was not. I then shut down the program, left the dongle and xmitter connected, waited a min or two and restarted the program, now everything is recognized and working.
Guess in addition to reinstalling and applying the updates in order from first to most recent the dongle and xmitter had best be connected before starting AeroFlyPro Deluxe.
It's working. :-}
It's working. :-}
OR
Now what I would really like is to have AeroFlyPro Deluxe recognize my RealFlight G4 Interlink Controller.
Right now it does not.
I have all the updates and of course the dongle is plugged into a USB port, but AeroFlyPro Deluxe still does not recognize the Interlink Controller.
Does anyone have a solution that will enable the use of the RealFlight G4 Interlink Controller to practice flying with AeroFlyPro Deluxe?
Thank you for your help.
OR
Hi Rajul,
The last time I tried, (which was before I read your last messge) I could not find any indication that AerolfyPro Deluxe recognized the controller in anyway at all.
Are you suggesting that I use windows 'Game Controllers' to set up the controller as a joystick? OR are do you simply mean to choose a joystick that indicates 2 sticks, 3 switches, one knob, and ? buttons?
I will of course try that to see if I get any response that indicates the program can see the controller.
Thank you.
OK
From within Aeroflypro Deluxe, I clicked on 'Controls' and 'Aircraft Control Settings' appeared.
I clicked on 'New' first, with Transmitter highlighted,
The configuration window that opened indicated "NEW"
I moved the control arms and switches around and nothing on screen responded.
I then clicked the 'Advanced' button and moved control arms and switches, still nothing responding.
I then clicked on a radio channel button, and in the 'Select channel' window,
moved control arms and switches trying to see if anything showed up, nothing responded.
I tried the same under joystick, and every choice except "USB Interface/GameCommander" was grayed out and not accessible to choose.
Nothing I tried indicated that the "RFG4 Interlink Controller was recognized.
P.S. I have all of the AFPD updates installed.
Thank you.
OK
Moderator
My Feedback: (58)
In some cases there could be a usb conflict. Try connecting the interlink to other usb ports. When you plug in your G4 controller and then go to your computer's "control panel" and select game controllers, do you see the G4 controller recognized? How did you connect your interlink to the PC? Did you use the cable that goes through the antenna receptacle, or the cable behind the controller?
OR
Hi Mark,
I have been connecting the Interlink Controller by the USB cable coming out the top of the controller.
I assume that it does not put out a PPM signal.
In the Control panel the controller is recognized and fully configurable. I can also practice with RealFlight G4 with no problems.
There are no USB conflicts indicated, at least there are none that show up in Device Manager under "Human Interface Devices" or "Universal Serial Bus controllers."
I am guessing that a software or registry problem has been created, possibly by one of the upgrades, causing the grayed out options to be unavailable.
OR
I am beginning to think their may be something wrong with my AFPD cable.
Once again when I connect my t9chp transmitter it is not recognized when using AFPD.
However when I use Reflex XTR the transmitter is recognized and works fine.
It seems the only logical conclusion is that the cable is going bad or getting faulty?
Are there other options possible given what has occurred?
Oh, by the way the radio is set to ppm.
I purchased my cable at the same time I purchased my software from (http://www.ohiomodelplanes.com/)
That purchase was made well over 2 years ago.
Moderator
My Feedback: (58)
Hi driftair, did your 9C radio switch on when you plugged in the adapter cable?
Pls plug in your AFPD interface cable and your 9C radio and run AFPD. Then look for the tmlog file in your AFPD program directory. You can find open the file with a text editor like word or notepad. Post your tmlog file here so that I can take a look at it.
OH
Mike, I'm having a similar problem.
My computer (HP laptop running Vista Home Premium) was actually running the program flawlessly until yesterday.
Now the controls are erratic and, when I attempt to calibrate, the dialogue box keeps changing the number of detected channels.
I've tried 3 different transmitters (JR 8103, 6102, Spektrum DX7) with the same results.
I think it's the dongle....I've had trouble with it before. It once had a similar problem and I found when removing the shrink wrap some bad solder connections. I repaired them and all was well for awhile, but now the problem has returned and there is no visible issue with the board. I'm getting a bit disgusted. I have never had so much trouble with any other peripheral.
Where can I send it for evaluation/replacement? I think I bought the upgrade from an outfit in Cinncinnati or Dayton, Ohio but I can't find the record.
Rick
Rick
OR
Hi Mike,
Yes, my 9C radio does switch on when it is plugged into the adapter cable, in fact the xmitter radio turns on even if the adapter cable is not connected.
The contents of the "tm.log" follow.
tm: Library Version 4.4, Copyright (C) 1999-2007, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 1315064944
tmsystem: cpu type=(nlogical=1) (nphysical=1) (no hyper-threading)
tmsystem: cpu=1470 Mhz
tmsystem: memory=(physical=1535MB, avail=990MB) (virtual=2047MB, avail=1886MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.11.7.9, Copyright (C) 1998-2007 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
openal: register sound sound/beep.wav=(0, rd=100.00) ok
openal: register sound sound/balloon.wav=(1, rd=100.00) ok
tmgl: failed to load texture texture/photoeye.bmp
openal: register sound sound/crash.wav=(2, rd=100.00) ok
openal: register sound sound/splash.wav=(3, rd=100.00) ok
openal: register sound sound/glider.wav=(4, rd=2.00) ok
openal: register sound sound/glider2.wav=(5, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(6, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(7, rd=5.00) ok
openal: register sound sound/glider.wav=(already registered)(already registered)(8, rd=2.00) ok
openal: register sound sound/glider2.wav=(already registered)(already registered)(9, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(already registered)(already registered)(10, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(already registered)(already registered)(11, rd=5.00) ok
tmgl: failed to load texture texture/cockpitmain.bmp
tmgl: loading geometry objects/horizon.obj= ok
afdesign: init ok
tmgl: loading geometry objects/card.tgo= ok
tmgl: loading geometry objects/pylon.obj= ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=816x632) (screen=1680x1050) (32bpp) (60Hz) (window)
openal: init (default=Generic Hardware) (0:Generic Hardware) (1:Generic Software) (version=1.1) (1.1) (Generic Hardware) (Generic Hardware) ok
init pixelformat=ok
gl: vendor=ATI Technologies Inc., renderer=RADEON 9600 SERIES x86/MMX/3DNow!, version=2.0.6956 WinXP Release, opengl version=2.0
(viewport=4096x4096) (texturesize=2048) (stencil=8)
gl extensions=GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ARB_draw_buffers GL_ATI_draw_buffers GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_object GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_extensions_string WGL_EXT_swap_control
wgl extensions=WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_extensions_string WGL_EXT_swap_control WGL_ATI_render_texture_rectangle
gl: extensions=(multitexture) (framebuffer) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps) (shader objects)
wgl: extensions=(wglpixelformat) (swapcontrol) (multisample)
tmsystem: fullscreen modes=(rj-640x480x16x60) (rj-640x480x16x72) (rj-640x480x16x75) (rj-640x480x32x60) (rj-640x480x32x72) (rj-640x480x32x75) (rj-720x480x16x60) (rj-720x480x16x75) (rj-720x480x32x60) (rj-720x480x32x75) (rj-720x576x16x59) (rj-720x576x16x60) (rj-720x576x16x75) (rj-720x576x32x59) (rj-720x576x32x60) (rj-720x576x32x75) (800x600x16x56) (rj-800x600x16x70) (rj-800x600x16x72) (rj-800x600x16x75) (rj-800x600x32x70) (rj-800x600x32x72) (rj-800x600x32x75) (rj-848x480x16x60) (rj-848x480x16x75) (rj-848x480x32x60) (rj-848x480x32x75) (rj-1024x480x16x60) (rj-1024x480x32x60) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x72) (rj-1024x768x16x75) (rj-1024x768x32x70) (rj-1024x768x32x72) (rj-1024x768x32x75) (1152x864x16x60) (rj-1152x864x16x70) (rj-1152x864x16x75) (rj-1152x864x32x70) (rj-1152x864x32x75) (1280x720x16x60) (rj-1280x720x16x75) (rj-1280x720x32x75) (1280x768x16x60) (rj-1280x768x16x75) (rj-1280x768x32x75) (1280x800x16x60) (rj-1280x800x16x75) (rj-1280x800x32x75) (1280x960x16x60) (rj-1280x960x16x70) (rj-1280x960x16x72) (rj-1280x960x16x75) (rj-1280x960x32x70) (rj-1280x960x32x72) (rj-1280x960x32x75) (1280x1024x16x60) (rj-1280x1024x16x70) (rj-1280x1024x16x75) (rj-1280x1024x32x70) (rj-1280x1024x32x75) (1360x768x16x60) (rj-1360x768x16x75) (rj-1360x768x32x75) (rj-1360x1024x16x60) (rj-1360x1024x16x75) (rj-1360x1024x32x60) (rj-1360x1024x32x75) (1440x900x16x60) (rj-1440x900x16x75) (rj-1440x900x32x75) (1680x1050x16x60)
tmsystem: opengl samples buffers=4
directinput: searching joysticks=none
(1: (1: (110rogramobject: Link successful. The GLSL vertex shader will run in hardware. The GLSL fragment shader will run in hardware.)
framebuffer object created (512, 512)
framebuffer object created (256, 256)
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=radiointerface
tmsystem: searching usb interface (1) 1=unable to open interface device
tmsystem: searching usb interface (0) 1=unable to open joystick device
tmsystem: searching usb interface (1) 1=unable to open joystick device
tminput: 1 devices found
tminput: searching for input devices...(2)
tmsystem: searching dummy usb interface (0) 1=unable to open interface device
tmsystem: searching dummy usb interface (0) 1=unable to open joystick device
tminput: checking for joystick 0=fail
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (pano=0) (compress=1) named winzeln/winzeln=(3.600x4.000) (5x5) (20x10)
sim: sphere params(0)=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=tmgl: loading geometry scenery/winzeln/winzeln.obj= ok
ok
sim: loading time=706186 mus
sim: 1 photo scenes
tmcollision: 1604 triangles using 205312 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6) octmin=(40.0,40.0,40.0)
tmcollision: otnodes=73 otendnodes=37 otdepth=17 otlistareas=25349
tmcollision: otnmaxareas=219 otnavgareas=57 otnminsize=(39.063,39.063,30.883)
tmcollision: otareas=2124 mem=213808
tmcollision: 73 octrees, using 11096 bytes
tmcollision: total mem=224904 bytes
tmcollision: time=0.06s
tmcolldynamic: no dynamic objects or triangles
file = aircraft/christeneagle/christeneagle.tgc
sim: loading aircraft 1 christeneagle...
tmgl: loading geometry aircraft/christeneagle/christeneagle.obj= ok
tmdairfoil: loading naca0015 ok
tmdairfoil: loading flat ok
tmdairfoil: loading naca0009 ok
openal: register sound sound/g15-3000.wav=(12, rd=4.63) ok
openal: register sound sound/g15-5000.wav=(13, rd=4.63) ok
openal: register sound sound/g15-10000.wav=(14, rd=4.63) ok
generating shadow 0=radius=2.35 bbmin=(-1.41 -1.41 -0.51) bbmax=(1.41 1.41 0.29)
sim: creating blurr=Propeller
loading input device calibration config/radio0.tmc=ok
tmmusic: off
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=7943) -36 4) 88 (4977393E)
openal: shutdown=ok
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
I hope this helps to locate a solution to the problem.
Thank you.
P.S. OH! by the way my dongle is also one of the old versions, shrink wrapped in black.
afdesign: init ok
init pixelformat=ok
ok
sim: 1 photo scenes
tmmusic: off
openal: shutdown=ok
Thank you.
Moderator
My Feedback: (58)
Hi driftair, thanks for the tmlog file. It looks like there could be an open connection in the usb interface or the adapter. Please ship your usb interface cable and the adapter to the service department below with a brief description of your problem and daytime phone number. You may attach this thread for reference.
IKARUS-USA
Service Department
Billy Creek Commerce Center
5876 Enterprise Parkway
Ft. Myers, FL 33905
ph. 239-690-0003
fax 239-690-0028
IKARUS-USA
Service Department
Ft. Myers, FL 33905
ph. 239-690-0003
fax 239-690-0028
Moderator
My Feedback: (58)
Hi Rick, it looks like your usb interface has become faulty. The shrink wrap version of the usb interface that you have is the older version. The new version has a molded casing. Please ship your usb interface cable to the service department below with a brief description of your problem and daytime phone number. You may attach this thread for reference. Please request for a change to the new molded case version.
IKARUS-USA
Service Department
Ft. Myers, FL 33905
ph. 239-690-0003
fax 239-690-0028
IKARUS-USA
Service Department
Ft. Myers, FL 33905
ph. 239-690-0003
fax 239-690-0028
OR
Thanks Again Mike,
Today I sent the adapter in to: IKARUS-USA
Service Department
Ft. Myers, FL 33905
As recommended.
Clark
Service Department
Ft. Myers, FL 33905
As recommended.
Clark
Help!!! I have AFDProf. ver. 1.9.1.3 and all works fine. I downloaded update ver. 1.11.7.9 and all I get is that I need openGL 2.0 of better and the program won't run. I'm using a Radeon 9250 card with the following info:
Driver Packaging Version 8.252-060503a-038185C-ATI
CATALYST® Version 06.11
Provider ATI Technologies Inc.
2D Driver Version 6.14.10.6614
2D Driver File Path System\CurrentControlSet\Control\Video\{4A3F9409-2C05-49EF-9B43-55986C796458}\0000
Direct3D Version 6.14.10.0399
OpenGL Version 6.14.10.5819
CATALYST® Control Center Version 1.2.2314.20337
I think it should work. What am I missing here? []
Baytrl
Baytrl
OR
Hi Baytel,
I think you need to download and install the most recent version of DirectX
Try the following link
http://www.gamesforwindows.com/en-US...rectx10-a.aspx
P.S. You may want to check for the latest drivers for your graphics card at the link below.
http://www.sapphiretech.com/en/support/drivers.php
