Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Please Help with AFPD
Old 08-28-2007 | 07:40 AM
My Feedback: (14)
Default Please Help with AFPD
please i need your help with my AFPD..the problem i am having is half the jet's that I have in my AFPD have no elevator control up or down.....the others are ok....my 3D planes don't fly smooth...they fly jittery in rolls........everything use to be fine...don't know what changed? do I need to reinstall my AFPD? I have a new Dell 700 2.99GHz with Windows XP Pro with 4 gig's of ram...the video card is a Gforce 7900 GS 256ram....the pc does everything else fine..plays pc games, video's fine.......have done a complete pc check with Dell dianogtics and everything was fine.......so I am lost as to why my AFPD does not peforme like it use to.......thanks for any help on this problem.
Old 08-28-2007 | 07:51 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: Please Help with AFPD
Max, do you have the interface version or the game commander version? Did it use to work well on the same computer system? Thx
Old 08-28-2007 | 08:28 AM
My Feedback: (14)
interface version with a futaba 7 uap.........it did work good on this pc berfore....thanks for any help...Max[]
Old 08-28-2007 | 08:33 AM
rajul's Avatar
Moderator
My Feedback: (58)
Did you get any error message in AFPD during startup?
Old 08-28-2007 | 08:40 AM
My Feedback: (14)
rajul
no never......the planes just don't fly right like they use to.......thanks
Old 08-28-2007 | 08:48 AM
rajul's Avatar
Moderator
My Feedback: (58)
If you're using dual rates on your radio, try calibrating AFPD at high rates. Let me know if you still see the jitter after calibrating at high rates. Do you have another radio you can use? This may help to isolate the problem.
Old 08-29-2007 | 06:18 AM
My Feedback: (14)
rajul
thank you......i am going to try another pc and see if that helps.
Old 08-29-2007 | 08:52 AM
exeter_acres's Avatar
I'm reading in to this....
You have a "New Dell"
......i am going to try another pc that everything worked great..
has it EVER worked on the new computer? or just on the old one?
Did you install the software on the new system or just move it??
Old 08-29-2007 | 09:44 AM
My Feedback: (14)
I install the software on the new system and i believe it it did work good but i can't be sure since i use the 3D'S more than the jets.......but some jets work fine while others have no elevator and i know they all did before and on the 3D planes i see the problem the most in the rolls . i have always set my radio and program up in high rates.....i was thinking that maybe its the cord that goes from my USB port to my futaba 7 chanel transmitter? iam going to take the cord and transmitter tonight and try it on a pc that i know all worked fine......i thank all of you for helping me with this problem.......Max
Old 08-29-2007 | 09:47 AM
rajul's Avatar
Moderator
My Feedback: (58)
Max, keep me updated
Old 08-29-2007 | 10:25 AM
My Feedback: (14)
rajul
thank you..i will.....have a great day...Max
Old 09-01-2007 | 03:07 PM
My Feedback: (14)
rajul
i want to thank you for all your help.....i did install it on my 600 dell and it worked fine so i removed it off the 700 dell and reinstalled it now all the planes fly great.....i must of had a bug in the program and removing it and re installing it took care of the problem.........have a great long weekend....thanks Max
